Fuel leaking from Air cleaner (Ear?) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 02-16-2012, 11:25 PM Thread Starter
Hello everyone, this is my first post here. I'll be picking up my 1988 Vulcan750 Saturday morning and am very excited, its in really good shape the only issue is that one cylinder floods if ran for a while and fuel is leaking out of the air cleaner housing or Ear I think you guys call them. The seller tells me that it just needs the carbs cleaned, unfortunatly I know nothing about carburetors. I searched and found the awesome disassembly/ assembly video and I think I can handle cleaning them myself. I just wanted to know if this sounds like something that needs to be cleaned, or something that may be out of adjustment and harder to determine. If this is a dumb question I'm sorry I really did search. I'm just clueless when it comes to carbs. Thanks
xezerax is offline
post #2 of 26 (permalink) Old 02-17-2012, 03:39 AM
If it's a float that is stuck, you could try to pull out the drain screw and shoot some carb cleaner into it and tap on it a few times with a screwdriver handle. It's worth a try....
post #3 of 26 (permalink) Old 02-17-2012, 08:33 AM
JM2001's Avatar
X2 Sounds like a stuck or bad float.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 26 (permalink) Old 02-17-2012, 09:24 AM
yeah, a stuck float
I had that problem.... pulled the carb's & found a piece of stock air filter foam in float valve... lol......Replaced float valves & new air filters installed.
Good Luck
WilliamTech
post #5 of 26 (permalink) Old 02-17-2012, 09:59 AM
1986vn750's Avatar
Our 1986 did the same thing. front cylinder floods, problem was a leaking fuel tap. make sure yours is sealed when in the "on" position.
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #6 of 26 (permalink) Old 02-17-2012, 10:58 AM Thread Starter
Cool thanks for all the quick responses now at least i know what area to look in..
sorry again but what/where is the fuel tap?
xezerax is offline
post #7 of 26 (permalink) Old 02-17-2012, 11:19 AM
flitecontrol's Avatar
Fuel tap = petcock. Make sure the petcock isn't leaking gas when the engine isn't running. Pull the two fuel lines (the outer ones) and see if fuel continues to come out of either side. If it does, the petcock should be rebuilt or replaced.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #8 of 26 (permalink) Old 02-17-2012, 12:18 PM Thread Starter
Ok got it thanks
xezerax is offline
post #9 of 26 (permalink) Old 02-17-2012, 04:05 PM
1986vn750's Avatar
And just incase you're still unclear, it is located on the left side, near the back of the gas tank. pointing down is "on"
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #10 of 26 (permalink) Old 02-21-2012, 08:43 PM Thread Starter
Just a little update, after about two and a half angry hours I finally got the carbs out. Holy hell you guys weren't kidding about it being a tight fit, I have a lot of respect for those that have done it themselves. I'm going to let them sit outside until tomorrow to air out a bit before I pull them apart. I think in the mean time I'll be looking into an air box delete...
xezerax is offline
