Fuel coming out of vacuum port. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 02-03-2012, 03:23 PM Thread Starter
Ceal's Avatar
My bike started acting funky... I swear this bike hates me, I put nice stuff on it to fix it and it immediately acts up! lol.
So I was riding to work and suddenly it started to die on me. It wouldn't idle but I kept it alive by giving it some throttle when I had to stop.
If I stopped and didn't open up the throttle a bit, it would idle for a few seconds then the RPMs would go down until it died.
I got it home after applying the same technique and parked the bike. Went to my 2nd workplace by cab and when I came back there was a puddle of gas beneath the bike.
Started looking for the source of the leak and when I unplugged the vacuum port on the right carb, fuel came streaming out of the vacuum port.
Doesn't seem to have happened with the left carb, though maybe that one drained completely by the time I got home?
So anyway, what do you guys think about this? I'm pretty sure I'll have to take the carbs off AGAIN u_u
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #2 of 13 (permalink) Old 02-03-2012, 04:24 PM
Calif Rider
weh44att's Avatar
I would think that the float in that one carb is stuck. Check the plug on that cylender and see if it is black, running rich. On the left carb you can check to see if it has fuel by draining the carb by the drain at the bottom of the carb.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 13 (permalink) Old 02-03-2012, 09:13 PM
romeobravo172
romeobravo172's Avatar
Are you sure it wasn't that new "puck" LOL, By the way pay pal came thru quick!
romeobravo172 is offline
post #4 of 13 (permalink) Old 02-04-2012, 12:13 AM Thread Starter
Ceal's Avatar
I think it was... I think my bike is so spoiled it acts up even when I'm trying to fix it! lol
I'm gonna start checking out stuff tomorrow. I'll report if there was still fuel in the other carb and if I see any obvious stuff wrong with the carbs.
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #5 of 13 (permalink) Old 02-04-2012, 03:10 PM
What do you mean by "vacuum port"? There is only one vacuum port, or connection on each carb. The front one is connected to the vacuum operated petcock. the rear one is either capped off, or connected to the air injection system. I don't see any way gas could leak out of either one of these.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 13 (permalink) Old 04-24-2013, 03:12 AM
Same Situation here, fuel broke down rubber vac cap
Noticed fuel leak and found vacuum cap on rear (right) carb has been melted by fuel, pulled off rotten cap and fuel coming out of port, especially when I turn the throttle...Seems like diaphram or stuck float, but wondering what "ceal" found.....I know this is an old thread, I might have to start another one.
89 750 Vulcan
shaved, coastered, cone filters and rejetted, Tim Parrot Stator
Dekka, AGM battery All lights are LED except headlight
dalesteraz is offline
post #7 of 13 (permalink) Old 04-24-2013, 10:26 AM
I think Ceal's was the one that was leaking fuel through the petcock and into the vacuum hose. Sounds like you're at least coastered, so it must be a float problem.
post #8 of 13 (permalink) Old 04-24-2013, 10:36 AM
I had a slight leak with the Petcock....also noticed slight amount of fuel getting sucked thru the vacuum, I rebuilt petcock... stopped the leaks.
....just sayin'
x2
post #9 of 13 (permalink) Old 04-24-2013, 11:11 AM Thread Starter
Ceal's Avatar
Mine was on the rear carb as well, not the front one that goes to the petcock.
In all honesty, I can't remember what I did to fix it. I wonder if this is when I parked my bike for months last year... can't remember. This is exactly why I'm trying to come back and explain what fixes my problems on my newer threads lol.
I know for a fact that I replaced my petcock, and I know for a fact that I didn't buy any carb diaphragms or any other carb parts. So that leaves a stuck fuel float as the problem... or the leaking petcock somehow made the rear carb flood? Less likely, I think.
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #10 of 13 (permalink) Old 04-24-2013, 11:36 AM Thread Starter
Ceal's Avatar
Looked at some of my older posts, and what I did was take off the carbs, disassemble them and clean them, then put them back in. So yes, it was a stuck float!
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
