Pingel Fuel Valve (Petcock) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 01-30-2012, 08:51 PM Thread Starter
Patriot Guard Rider
The DEUCE's Avatar
Who's using one? what do you think? what p/n did you purchase?
My petcock is leaking again and I refuse to rebuild it.
http://www.pingelonline.com/fuel_valves.htm
VN750 #9300 & VROC #33453
The DEUCE is offline
post #2 of 7 (permalink) Old 01-31-2012, 02:10 PM
post #3 of 7 (permalink) Old 01-31-2012, 11:08 PM Thread Starter
Patriot Guard Rider
The DEUCE's Avatar
Slim, that is the exact one I was looking at (3211-D-AH) but I am having a problem spending $108.55 plus $30.60 for the adapter plate. There's got to be a more economical solution.
post #4 of 7 (permalink) Old 02-01-2012, 12:19 PM
no need for the adapter plate... unless you don't have any fabrication skills.
Materials needed 1/8" X 1" by 3" piece of aluminum
tools needed: Jigsaw with metal blade (hacksaw will work too), File, Drill, drill bits, and a tap for the fuel petcock hole.
take the old fuel petcock base to use for a pattern. (trace out onto cardboard, manila envelope, or suck other stiff paper) transfer the pattern to the piece of aluminum
drill the small holes for the screws, then drill the large hole for the petcock. Tap the petcock hole.. and presto you are done.. and should only cost about 10 bucks...
post #5 of 7 (permalink) Old 02-01-2012, 02:30 PM
ohh yea... forgot to mention the need for gasket material to go between the tank and the plate
post #6 of 7 (permalink) Old 02-05-2012, 06:07 PM
Hoser
junkyardroad's Avatar
Rather than build an adapter to mate a new petcock with your stock tank, I would highly recommend cutting the old mount out of the tank, welding in a patch, drilling the patch out for a 3/8 npt weld bung, and threading in a new Pingle dual outlet petcock.
It would be about 2.5 inches with a wire feed, cutting with something like a dremel, a permanent fix for a crappy stock setup.
The Pingle valves are worth the money.
1986 VN750A(2) 12224 miles.
junkyardroad is offline
post #7 of 7 (permalink) Old 02-06-2012, 12:27 PM
Joem's Avatar
You can order a new one from Kawasaki for $96. 10 minute job max.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
