Fuel problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 12-15-2011, 03:23 PM Thread Starter
Ceal's Avatar
Fuel problem
Went out to my bike to find the floor stained with gas. It's been raining, so the gas puddle is gone but there's the stain still there and the smell.
Also, my tank is now empty u_u I let the bike sit since Tuesday. I hadn't gone out to it since then and now this is what I found.
So I'm guessing my carbs need to get kicked out again. I think the petcock is working right, I rebuilt it a few months ago and I haven't seen it leak since then. Can't really test it right now since I have no fuel in the tank u_u
So what should I concentrate on? Floats and needles?
Anyone wanna give me a set of good working carbs for Christmas? lol
My damn "new" hockey puck is also acting up... I don't seem to have good luck with those lol but that goes on another topic altogether.
Ceal is offline
post #2 of 14 (permalink) Old 12-15-2011, 04:46 PM
Patriot Guard Rider
The DEUCE's Avatar
I'll bet it is still your petcock. I rebuilt mine and it decided to leak on me again.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 14 (permalink) Old 12-15-2011, 05:29 PM Thread Starter
Ceal's Avatar
Well, the leaking appeared to be from the carbs rather than the petcock, judging by the fuel drops that I found around the carbs... Still, I will definitely test the petcock once I get some gas in the tank. Don't have a car right now to go get gas :-/ so it will have to wait a bit.
Ceal is offline
post #4 of 14 (permalink) Old 12-15-2011, 06:00 PM
I know I've read several posts about the floats sticking alowing the fuel to flood the carb & leak out. Without a tear down, you could always try the great "Sea Foam", if it's available to you.
Either way, it shouldn't be anything to major. You can get to the float bowls easy enough & check them to see if they're stuck!
post #5 of 14 (permalink) Old 12-15-2011, 07:42 PM
If only it had 6th gear..
DavesVulster's Avatar
I would agree about the petcock except going back to what I know about carbs, but taking into account that these are different for sure, the float needle valves are to my knowledge solely responsible for regulating the fuel in the carbs at any given time. The petcock is only on or off so when the bike is running and producing vacuum, gas flows until the floats are satisfied and then flow is stopped to prevent flooding (provided that your PC diaphragm is in tact). The PC is still open at this time though -the needle valve has stopped the flow. I fully admit that I could be missing something that happens when the bike is sitting but, when you look at the design of each carb individually, you have a gas line that feeds directly to the float valve. There is no other feed so, theoretically you should be able to put your valve on "PRI" (on older bikes of course) and there should no leak if the floats are working properly.
I missed something There is the possibility of the diaphragm having a tear or pinhole in it but that should only allow gas to enter through the vacuum port while the engine is running not sitting. This could be easily checked by plugging or pinching the vacuum line to the petcock while it sits for a while to see if it still leaks. Or if you have a vac pump you could use it to see if it pulls gas from the petcock vac line.
I love to learn more about these bikes, so let me know if I haven't got it right or missed something.
And Ceal, sorry you're having troubles still with the stuff you've already replaced. Very frustrating. Good luck.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #6 of 14 (permalink) Old 12-15-2011, 07:43 PM
flitecontrol's Avatar
If the petcock was operating properly, it shouldn't have allowed gas to get to the carbs with the bike off. Not sayin' the carbs aren't defective too, but the petcock definitely is.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 14 (permalink) Old 12-15-2011, 08:24 PM Thread Starter
Ceal's Avatar
hmm good points here... definitely need to take a good look at everything.
I didn't see the petcock leak before, but this time I think I left it on the "res" position, maybe that position isn't working as it should and the "on" was working right... I dunno, I'll update when I can check the petcock.
Ceal is offline
post #8 of 14 (permalink) Old 12-15-2011, 10:06 PM
If it hasn't been modified from stock, the petcock shouldn't freely flow gas except in the Prime position.
"Black Beauty"
Old Blue
post #9 of 14 (permalink) Old 12-15-2011, 10:39 PM
Right. Like if it doesn't fully close and lets gas seep when the bike is off.
Lets say the floats are ok. Do you think if the diaphragm had a hole in it and the valve never fully closes, gas could seep into the carbs thru the vac port by gravity? Just thinkin about stuff...
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #10 of 14 (permalink) Old 12-15-2011, 11:36 PM
I would say it is definitely a possibility ,and there could be some crud holding it open also.But definitley the petcock needs looked at ,I wonder does this petcock have pri,position or is it on, off and reserve,as FC said if it says pri instead of res it will allow fuel through it without the bike running.Either way, it is a good reason for turning your petcock to the off position especially when parking for the day.
