Page 1 of 2 | 1 | 2 |
Bike idiles fine. Runs great until I get about 3-4th gear and over 40mph. Then it spudders, loss of power and seems as if I'm running out of gas. If I really gEt on the throttle it clears up till I reduce rpm and keep the throttle steady. This happens no matter what the fuel level is. Any ideas what could be going on?
Video I shot and edited of my 1985 Vulcan VN750
mounted iphone gps for speedo and milage
custom seat mod
stator replaced
mosfet r/r
gauges and dash removed
baffles drilled
synth oil
ear shave
de goat
412 progressive 11" shocks
Custom paint
NGK Iridium Spark Plugs
cam chain tightened
Coming soon:
spline lube
whitewall tires
Sponsored Links | |||
First...make sure throttle cable is free and lubed..also check your air filters and carb boots and hoses to see if anything is loose, broken or leaking.
also check your spark plugs to see if they are in good shape.
if not any of those, I'm guessing the carbs are clogged or dirty. Throw some Sea Foam in and see if it helps.
I am sure you will get plenty of good advice from the more experienced guys here, but I would start there.
Good luck...let us know what you find out.
Light Bar mounts:https://www.vn750.com/forum/showthread.php?t=23644
Turn signal light inserts LED:
https://www.vn750.com/forum/showthread.php?t=21752
https://www.vn750.com/forum/picture.p...pictureid=2537
2006 VN750
VROC # 34354
Crap, I WAS in 5th gear.
X2 for vacuum lines to the petcock. Also x2 for clogged pilot jets.
X2? Can u give me more info
. Sorry I'm not mechanic.
custom seat mod
stator replaced
mosfet r/r
baffles drilled
synth oil
ear shave
de goat
Custom paint
cam chain tightened
Coming soon:
spline lube
whitewall tires
Originally Posted by stereopath
View Post
Ahh! Ha sorry newbe
Also read on a different thread about rerouting the carb vent hose and replacing the gas tank vent hose. Seemed to work in a similar situation.
https://www.vn750.com/forum/archive/i...p/t-15212.html
Now I just gotta figure out where these hoses are located
custom seat mod
stator replaced
mosfet r/r
baffles drilled
synth oil
ear shave
de goat
Custom paint
cam chain tightened
Coming soon:
spline lube
whitewall tires
There is a small hose that runs into the back of the right airfilter box. This goes to a T that then runs to both carbs.
Sometimes the hose falls out, or it gets pushed in to far in the back of the airbox. Fix is to pull it out of the box, cut the end at a 45 degree angle and stick it back in..(this keeps it from bottoming out and blocking the opening)
Check your floats. I know the "get on it" part doesn't fit, but suggest you check them. Also see if petcock vacuum hose gets soft when hot. Could collapse. Oh, look for leaks in carb boots. Had the same problem over years. Many fixes, but drives good now.
I noticed the from head carb boot doesn't seem to be on al the way. Also all 4 of the rings that fasten them on where loose. Couldn't get the boot any farther on the carb side but did tighten all the rings. Didn't seem to help.
I had a friend do an ear shave and don't seem to have any hoses coming off the carbs besides the two fuel lines.
custom seat mod
stator replaced
mosfet r/r
baffles drilled
synth oil
ear shave
de goat
Custom paint
cam chain tightened
Coming soon:
spline lube
whitewall tires
View Post
Perhaps he capped them off? You need to find the vent tubes and replace the system or your fuel bowl will never fill properly...making the bike act like it's running out of gas...(which it is..)
You only have two hoses going to your petcock? That's a problem too....
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
