carb parts help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 11-08-2011, 05:17 AM Thread Starter
Question carb parts help
Due to some of the problems Ive been having lately, I plan on ordering a carb rebuild kit and a new air cut off valve. I will be ordering from this site
http://www.siriusconinc.com/search_r...earch&x=21&y=2
My question is that there is 2 air cut off valves listed. PN 88-k004 and 88-k001. Does anyone know which one is correct. They both say for my bike (91 vn750us) but just wanna make sure before ordering. Thanks for the help in adavnce.
yukonjon is offline
post #2 of 7 (permalink) Old 11-08-2011, 09:58 AM
My '86 750 (A2) (older style with the Prime Setting) Petcock rebuild kit was 18-2723.
I do not recognize
post #3 of 7 (permalink) Old 11-08-2011, 10:01 AM
(sorry, incorrect mouse click) the 88-K004 kit. Do u have the "Off" setting or the "Pri" setting on your Petcock ?
Good Luck
post #4 of 7 (permalink) Old 11-09-2011, 11:36 AM Thread Starter
I did the petcock rebuild already. More than happy with that. I have an erratic idle that will go to about 4000rpm and then back down to idle (1100rpm). This might be caused by the air cutoff valves so since im gonna rebuild the carbs im going to do those at the same time. I have the petcock that says off. Im just not sure which air cutoff valve to order since both list this bike.
yukonjon is offline
post #5 of 7 (permalink) Old 11-09-2011, 11:06 PM
If only it had 6th gear..
DavesVulster's Avatar
I would go with the k001. It lists our bikes from 85-06 and there's no change in the carbs through all the years. They're probably both exactly the same kits but the part numbers cross over or something.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #6 of 7 (permalink) Old 11-12-2011, 10:06 AM
The carb(s)
The carbs are Keihin model CVK34...they are also used on many other vehicles including ATVs and ArcticCat Snowmos...instead of spending on shipping, may wanna check around for a local ArcticCat dealer...*wink*
That way too, you can even match up the replacement parts.
post #7 of 7 (permalink) Old 11-28-2011, 08:28 AM Thread Starter
So I contacted the parts guy and he says the one of the kits has a slightly longer spring in it. Im not sure how this is possible due to no carb changes but if someone has their carbs apart and could measure the air cutoff valve spring length it would be great. Otherwise im going to order the kit that list all years and hope for the best.
yukonjon is offline
