gas cap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-12-2011, 12:36 AM Thread Starter
Ford
Send a message via AIM to dbking321
gas cap
soI have been fighting an issue with my bike for a bit that i thought was just a dirt carb but it seems to me the gas cap. i cleaned the vent line and no luck. when im riding it will lose the back cylinder and then run on just the front for a little then die. then it will somtimes restart on the front and the rear will kick in if you rev it really high. well the last time i had it out it died and I opened the gas cap and restarted it thinking mabey it would help and it did it was fine. so i closed and got on the highway to go home and it died opened it agian and road home with it open just fine.... so my question is do they sell a gas cap rebuild kit? or do i need to get a new one and how do i make my lock work with it?
dbking321 is offline
post #2 of 4 (permalink) Old 10-12-2011, 01:08 AM
Crap, I WAS in 5th gear.
I haven't messed with my gas cap as I have a CA bike and just removed my canister line and used a long hose running under the bike (to atmosphere.) According to Jerry there is a rubber O-ring in the gas cap that can swell shut- you will want to replace the o-ring. Some people just remove the o-ring, but that can cause gas to seep out a little, especially when full.
Kelly2001 is offline
post #3 of 4 (permalink) Old 10-12-2011, 01:48 AM
If only it had 6th gear..
DavesVulster's Avatar
take the cap off your tank then remove the screws on the underside of the cap (careful, there are several springs that will come off, and a little silicone check valve) and clean all the orifices. Lube the lock mechanism with Tri-flow and you should be all set. If you cleaned the vent line you just got a clog in one of the holes most likely. My cap was a mess and that tri-flow did wonders. Haven't had a problem since.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #4 of 4 (permalink) Old 10-12-2011, 08:14 AM Thread Starter
Ford
ill try it thanks
