Gas Guage Indicator Quit Working - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 10-03-2011, 01:12 AM Thread Starter
OldHipWesTex's Avatar
Send a message via Yahoo to OldHipWesTex
Grrrrrrrr.... fix one thing another one shows its ugly head. Ok guys, is it my guage on the forks or the sending unit from the gas tank before i start tearing her down again. Any one got an quick check method of troubleshooting this one? All donations appreciated
Vulcan #1 1993 - 28K
Vulcan #2 1999 - 26k
It All Comes Down To 3 Things:
#1 Fuel
#2 Spark
#3 Mechanical
Any One Fails - Then It Dont Run
____________________________________
ANTICIPATED MODS:
Build Fiberglass Fenders F/R
Mold & Cast New Turn Signals Lights
OldHipWesTex is offline
post #2 of 19 (permalink) Old 10-03-2011, 02:50 AM
Ceal's Avatar
You could probably check impedance from the sender unit to see if it's working right.
Somebody posted the right values for it but I don't remember them (it was probably OlHossCanada lol).
Ceal is offline
post #3 of 19 (permalink) Old 10-03-2011, 11:20 AM
And you can try taking the seat off to see if it's still plugged in....
post #4 of 19 (permalink) Old 10-03-2011, 01:38 PM
psvines's Avatar
How reliable is the fuel guage? Mine seems to fluctuate greatly so I tend to ignore it and just check the tank before riding and pay attention to the mileage. (kind of like those in an airplane).
psvines is offline
post #5 of 19 (permalink) Old 10-03-2011, 01:47 PM
When it says it's "Full".... Your tank is full. When it says "empty"... Your tank is likely empty....Everything in between is a rough estimate.
You can learn what the readings actually mean after a few years.....
post #6 of 19 (permalink) Old 10-03-2011, 03:24 PM
Could be a bad fuel gauge or a broken wire.
You can pull the sender and check for broken wires on the sending unit itself. There is a thin wire wrapped around a piece of plastic, and they start out close together, and separate as they go along. That wire is what changes the resistance to the gauge in the dash. If that wire is broken, then the gauge will quit working.
You can check the resistance with an Ohm meter. Hook the leads up to the wires from the unit, and slowly move the float and watch the readings. If the reading stays the same, you most likely have a broken wire. If the reading changes, then most likely the sender is good.
RakerBill is offline
post #7 of 19 (permalink) Old 10-03-2011, 11:06 PM Thread Starter
Thanks RakerBill,,, i checked the plugin under the seat and all was well there. But, went ahead and pulled the tank off,,,, did a quick check on the plug going to the fuel gauge indicator and the fuel indicator will slowly run up to full. I pulled the float system out of the tank and didnt see any thing wrong, but with the ohm meter their is no change in the ohms,, just shows and OPEN circuit, so, now,, i suspect the sending unit is bad, didnt see any broken wires or such .
Thanks to all !!!
#1 Fuel
#2 Spark
#3 Mechanical
ANTICIPATED MODS:
post #8 of 19 (permalink) Old 10-04-2011, 03:34 AM
Chucklehead
dragon159's Avatar
Sounds like yet another broken connection under the metal sheild on the sending unit. It can be repaired depending your skill with soldering iron and patience. But to verify if the guage is working, jumper the plug under the seat and turn the ignition on, should swing to full.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #9 of 19 (permalink) Old 10-04-2011, 10:17 PM
Rider on the Storm
EasyRector's Avatar
Yes, this happened to me once!
EZC
EasyRector is offline
post #10 of 19 (permalink) Old 10-04-2011, 10:25 PM Thread Starter
Yep the guage will swing to full crossing the wires, so i guess i will recheck the sending unit again.. didnt notice any broken wires but these eyes fail me from time to time. Thanks Guys !!!
#1 Fuel
#2 Spark
#3 Mechanical
ANTICIPATED MODS:
