Chronically Flooded Engine - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 09-25-2011, 06:23 PM Thread Starter
Hi all,
So here's the current situation on my slow-to-restore Vulcan.
She starts up fine on the first go but once I kill the engine, it's flooded, but only on the front cylinder. The plugs are wet with gasoline and black from previous carbon fouling. When I let the engine and plugs dry out, she'll start back up again no problem.
The carbs have just been given an overhaul by a mechanic, so I'm reluctant to blame them.
Any ideas about what's causing this and how to fix it?
drizdan is offline
post #2 of 10 (permalink) Old 09-25-2011, 07:19 PM
Is the choke prime going back down when the choke is turned off? That would be the little valves on each carb that is moved when setting choke.
post #3 of 10 (permalink) Old 09-25-2011, 09:23 PM Thread Starter
yep, both look fine.
drizdan is offline
post #4 of 10 (permalink) Old 09-25-2011, 09:47 PM
Crobins365's Avatar
Are those plugs really firing? If they aren't - or aren't consistently - you'll flood the cyl.
C
Crobins365 is offline
post #5 of 10 (permalink) Old 09-25-2011, 10:49 PM
If only it had 6th gear..
DavesVulster's Avatar
I agree. If you're pretty sure your carbs have been cared for correctly I'd look at ignition in that front cylinder although you should notice a lack of power or stutter from the engine though. The only other thing is if for some reason fuel is continuing to flow into that cylinder for a few seconds after you shut it down. Doesn't seem likely though. Isn't the front carb the one connected to the petcock diaphragm? Maybe there's a problem there.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #6 of 10 (permalink) Old 09-26-2011, 09:39 AM
JM2001's Avatar
Originally Posted by drizdan View Post
Hi all,
Sounds like your carb float is stuck open or the needle valve is not seating properly. You say the bike starts easily and back up again when dried out so I don't think it's an ignition problem.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #7 of 10 (permalink) Old 09-26-2011, 12:26 PM
Git-R-Done!
AZ Kev's Avatar
What about the petcock? The diaphragm in mine was bad, causing it to flood out all the time. Have you checked the petcock?
AZ Kev
Arizona Kev
1989 VN750
7800 orig mi when purchased Jan 2011
Turned 11,000 mi Nov 2011
Saddlebags
Taillight relocation kit
Chad's highway peg mounts
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
Otherwise, all stock
"But it's a dry heat - like the inside of an oven"
AZ Kev is offline
post #8 of 10 (permalink) Old 09-26-2011, 12:36 PM
Crap, I WAS in 5th gear.
Check the float levels- it's easy to do, and at least you can rule it out.
Kelly2001 is offline
post #9 of 10 (permalink) Old 09-26-2011, 04:41 PM
Are you using the run switch to kill the engine?... If so, try only turning the ignition off and leaving the run switch alone.
km60155 is offline
post #10 of 10 (permalink) Old 09-28-2011, 04:34 PM Thread Starter
Alright, so.
I changed out all the spark plugs and now she starts up well each time. But! In order to get the bike to run I need to start at about half choke, which feels wrong to me in 90 degrees New Orleans heat.
Also, I pulled the plugs and even though she's starting up reliably now (so it seems, for the moment at least) the plugs are still coming out wet and the brand new front cylinder plugs are already black with carbon fouling.
I feel like it's only a matter of time before it happens again, even if the bike is starting up now. Any ideas?
Oh PS - I was using the Run switch to kill the engine, and now am using the key. Is there really a difference in this?
drizdan is offline
