What is the correct part number/ best place to buy a #40 pilot jet? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 09-21-2011, 12:45 AM Thread Starter
I believe I need to step up my pilots from the stock 38. I am thinking I need a set of 40's but I am having some trouble finding them. Most sites I look at only list a 35 and a 38. So does anyone have the correct part number for a 40 and also what the best price for 2 of these are?
Thanks in advance
Cricketo99 is offline
post #2 of 12 (permalink) Old 09-21-2011, 11:46 AM
Crap, I WAS in 5th gear.
Keihin 424-22 specify size #40.
http://www.pjmotorsports.com/keihin-...tml#pilot/slow jets
Kelly2001 is offline
post #3 of 12 (permalink) Old 09-21-2011, 03:10 PM Thread Starter
Is this site probably the best/cheapest for these jets? Also does a #40 sound about right for me? I have a set of Jardine slash cut pipes and still have the stock ears but they have been drilled for better flow.
Thanks
post #4 of 12 (permalink) Old 09-21-2011, 04:10 PM
Thanks
what has been drilled?
where are you?
VoIPDoc is offline
post #5 of 12 (permalink) Old 09-22-2011, 12:29 AM Thread Starter
When I bought it the previous owner had drilled small holes in the outside of the ears in between the raised areas. I am in Roanoke, VA.
post #6 of 12 (permalink) Old 09-22-2011, 12:14 PM
Thanks
Don't know how their prices compare- I figured $7 a piece was reasonable, I could order online and they shipped within an hour.
Whether or not you upsize your jets depends on how the bike is running. If there is no hesitation at low-mid throttle, then you don't need to change the jets. I am putting 40s in mine and it's all stock because it surges. Changing exhaust doesn't require a jet change because there is virtually no effect on the fuel/air charge going through the intake- it is a much different story for 2-strokes.
post #7 of 12 (permalink) Old 09-23-2011, 12:33 AM Thread Starter
Well the reason I am thinking bigger pilots is because I have a hesitation at a little less than quarter throttle. I have tried adjusting the mixture screws but they have little effect. So I suppose I will go up to a 40 and give it a shot.
post #8 of 12 (permalink) Old 09-23-2011, 01:58 AM
If only it had 6th gear..
DavesVulster's Avatar
I bought mine from the info in this quote from VoipDoc. Very helpful;
Originally Posted by VoIP Doc View Post
Don't do the work twice!!
Here's what you need:
Parts: (see Figure 2)
1 Mikuni Needle Shims Item# 009-396 $6.95
2 Keihin PN: 99101-393 Main Jet Size: 142 $13.90
2 Keihin PN: N424-22 Pilot/Slow Jet Size: 42 $13.90
Total $34.75
Order from here You'll have them this weekend. If you prefer 140/40..order them.
Just scroll down 'til you find your part number....pick size. Done.
Call the guy...real easy to talk to. Knows his carbs
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #9 of 12 (permalink) Old 09-23-2011, 12:19 PM Thread Starter
Okay thanks, now do yall think a 40 will be big enough or should I go ahead and spring for the 42. I do plan to do the ear shave at some point just not sure when.
post #10 of 12 (permalink) Old 09-23-2011, 12:30 PM
I am at 1961' above sea level. I used 40 pilots and 140 mains, and 2 shims on each needle. Also I used k & n air filters. Filter #rc-2340. All this advise from Lance (Ron).
Also all this with after market pipes and ear shave. Ran great.
