Black Plastic Carb Inlet Nipple - Page 6 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #51 of 55 (permalink) Old 08-06-2014, 01:20 AM
Ceal's Avatar
Yeah....i did in the original thread about this subject...I just mentioned a "local custom" so a guy wouldnt need to pay shipping or wait....
http://www.cv-performance.com/harley-fuel-inlet-elbow/
My buddys shop locally sells em fer $11 each....
Ah ok... I have nothing like that available, so my mind immediately goes to online shopping lol.
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #52 of 55 (permalink) Old 08-06-2014, 04:35 PM
Originally Posted by VN750Rider/Jerry View Post
I suspect that the black plastic is susceptible to ethanol damage. Ethanol will cause the plastic to dry out and crack.
We all get that you HATE ethanol Jerry, but you can't go blaming every issue in the fuel system on ethanol.
it's getting old.
Plastic will become brittle with age even without the fuel...or the ethanol.
post #53 of 55 (permalink) Old 08-07-2014, 10:02 PM
Heat also makes plastic brittle.....and its funny, because it wasnt a Kawi design...its what Keihin put on all of em (Harley Keihins had em too)....dumb....just like CVKs....this winter Im changin sheit around....single 40mm carb, probably a Kuni....gonna make a mold, and investigate doing my own casting....I already built a forge capable of 2900 deg F....so, if I make it a lil bigger....I can cast.....and yes, if I set it up for it, I can make molten iron....so I'll make a 2 part ceramic cast....voila...aluminim melts atound 1500...and I have a source for blocks....prolly be easier....2900 is a whore to get to....
post #54 of 55 (permalink) Old 01-31-2016, 06:45 PM
Bump
OleDirtyDoc is online now
post #55 of 55 (permalink) Old 04-30-2020, 09:56 AM
MSattler's Avatar
They sell removal tools commercially, but you can DIY easily. Once the plastic is snapped off and just the brass nipple is left, you can tap the inside of it to fit a bolt. Before inserting the bolt, thread on a nut and washer, and a socket for a sleave, then thread it in, and tighten the nut...Voila ! "El Cheepo" puller !
Not my idea btw, saw it at a Harley forum for removal from CVK40 carbs.
"They sell removal tools commercially, but you can DIY easily. Once the plastic is snapped off and just the brass nipple is left, you can tap the inside of it to fit a bolt. Before inserting the bolt, thread on a nut and washer, and a socket for a sleave, then thread it in, and tighten the nut...Voila ! "El Cheepo" puller !
Not my idea btw, saw it at a Harley forum for removal from CVK40 carbs."
So I tried to make this puller from Wolfie's comments, and I threaded the brass inlet, but when I tighten the nut on the bolt that I threaded in, it just snugs the bolt to the inlet. Was I supposed to reverse thread the bolt or something? Could someone explain this like I am 5, please?
'08 Road King Classic
'86 VN750:
Ear Shave, K&N Filters, Mean Streak Seat, AGM battery, Blue Wire Mod, Pick-up Coil Mod, Timing Advance Mod, NGK Iridium Plugs and Wire, LEDs, Bed Liner Paint Job, Over-sized Tires, New Brakes, New Fork Seals, Progressive Springs, Kick Stand Mod, Highway Pegs, 40/140 No Shims, Vance & Hines Exhaust, New Grips, Extra Wide Emgo Handle Bars
John 8:44, REV 2:9, REV 3:9 - If you were kicked out of 109 bars, would you think the problem was you, or the 109 bars?
MSattler is offline
Tags
brass carb fuel nipple , carb fuel nipple
