Black Plastic Carb Inlet Nipple - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #21 of 55 (permalink) Old 10-25-2011, 07:44 PM Thread Starter
OldHipWesTex's Avatar
Send a message via Yahoo to OldHipWesTex
Yes i used the teflon tape for a sealer instead of using a liquid harder of any kind. As far as ever removing the brass fittings again, i dont know if i ever would, but, ya never know
I just know that those little brass fitting was a bummer to get out, didnt want to drill the brass out to far. Suppose ya could drop some propane or other cooler liquid on the fittings to remove them, but they are a Tight Tight fit. As far as being tapered, i didnt take that close of a look at them, they could be tapered. NOTE TO SELF: Find the old fittings and check for a taper!
Im sure other ridders will chime in with another way to fix the inlet fuel leaks too. The Hardly fittings seems like a good idea to, had i of known of them i probably would have went with the Hardly fittings. I can hindsight 100%
Vulcan #1 1993 - 28K
Vulcan #2 1999 - 26k
It All Comes Down To 3 Things:
#1 Fuel
#2 Spark
#3 Mechanical
Any One Fails - Then It Dont Run
____________________________________
ANTICIPATED MODS:
Build Fiberglass Fenders F/R
Mold & Cast New Turn Signals Lights
OldHipWesTex is offline
post #22 of 55 (permalink) Old 10-25-2011, 11:03 PM
Just BTW
They sell removal tools commercially, but you can DIY easily. Once the plastic is snapped off and just the brass nipple is left, you can tap the inside of it to fit a bolt. Before inserting the bolt, thread on a nut and washer, and a socket for a sleave, then thread it in, and tighten the nut...Voila ! "El Cheepo" puller !
Not my idea btw, saw it at a Harley forum for removal from CVK40 carbs.
post #23 of 55 (permalink) Old 10-25-2011, 11:10 PM Thread Starter
YES ! Another cool tip ! Thanks i will have to do that to the #2 Vulcan i purchase! Noted !!
#1 Fuel
#2 Spark
#3 Mechanical
ANTICIPATED MODS:
post #24 of 55 (permalink) Old 02-16-2012, 09:25 PM
Patriot Guard Rider
The DEUCE's Avatar
Originally Posted by OldHipWesTex View Post
I found that by drilling the hole in the brass plug bigger and with a second drill bit even bigger that the plugs will just slide out with a pair of pliers. Caution: when drilling the hole bigger to get the factory plug out, be carefull not to drill to deep or you will push the drill bit out the side of the plate. I measured how deep the factory pressed in plug went then marked how deep to drill with the drill bits. Think about it before drilling to deep.
Here is a safer way to remove the brass plug.
http://www.cv-performance.com/fuel-elbow-replacement/
VN750 #9300 & VROC #33453
The DEUCE is offline
post #25 of 55 (permalink) Old 02-27-2012, 12:13 AM Thread Starter
Yeppers, that one works too !
#1 Fuel
#2 Spark
#3 Mechanical
ANTICIPATED MODS:
post #26 of 55 (permalink) Old 02-29-2012, 09:47 AM
MaDeInSin's Avatar
Have not seen you in a while WesTex!
Glad to see you out and about!
Cheers!
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #27 of 55 (permalink) Old 06-23-2012, 12:41 PM
They sell removal tools commercially, but you can DIY easily. Once the plastic is snapped off and just the brass nipple is left, you can tap the inside of it to fit a bolt. Before inserting the bolt, thread on a nut and washer, and a socket for a sleave, then thread it in, and tighten the nut...Voila ! "El Cheepo" puller ! Not my idea btw, saw it at a Harley forum for removal from CVK40 carbs.
Haven`t looked at this thread for a while and just realized that Wolfie`s explanation for a DIY puller is illustrated in The DEUCE`s link.
post #28 of 55 (permalink) Old 06-23-2012, 10:40 PM
Yeppers, it sure is, same thing...I just used a socket and shorter bolt is all.
...dint have no need to buyt a pipe nipple, had the sockets...
I used a hex head bolt too instead of a slotted screw. Its whatever was layin' around, lolol...
post #29 of 55 (permalink) Old 06-26-2012, 05:25 AM
Just ordered a couple of these, best price I can find:
http://www.ebay.ca/itm/271005352819?...84.m1438.l2649
gaillarry is offline
post #30 of 55 (permalink) Old 07-13-2012, 11:50 AM
Thanx for the pics !!!!
rkama354 is offline
Tags
brass carb fuel nipple , carb fuel nipple
