I just rebuilt the leaking fuel tank petcock...... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 09-19-2011, 11:15 PM Thread Starter
Smile I just rebuilt the leaking fuel tank petcock......
Fuel Petcock ’86 vn750
I just rebuilt the leaking fuel tank petcock, installed tank on bike and dumped a gallon of fuel in. I needed to remove remove tank again, and when I pulled the fuel lines off the petcock, fuel poured out of the petcock.
The petcock has “Pri” , “On”, & “Pri” settings.
Question: Doesn’t the vacuum from the left carb control the petcock fuel flow ?
Any assistance is much appreciated.
Tia
WilliamTech
post #2 of 3 (permalink) Old 09-20-2011, 12:09 AM
If only it had 6th gear..
DavesVulster's Avatar
Yes the petcock should only flow when vacuum is applied.... unless you have it in the 'PRI' position. Then it will flow no matter what. That position is only used to prime the float chambers. But when 'ON' or 'RES' no fuel should flow at all until engine runs. Did a new diaphragm come with the rebuild kit? If gas flows in those other positions I wonder if the diaphragm spring is seated correctly.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #3 of 3 (permalink) Old 09-20-2011, 01:10 AM Thread Starter
Yes, something along that line is wrong. I will take it apart tomorrow in attempt to correct my wrongs.
LOL
