smoking and backfiring problems!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-16-2006, 04:31 PM Thread Starter
I am having trouble tuning my VN750. The engine starts up fine, but once it gets warmed up it smokes heavily, backfires both through the exhaust and I can hear it backfiring through the carbs. I took the carbs off and cleaned them with carb cleaner. They had a little rust in there from the tank. But other than that the jets were all clear. I put them back on, adjusted the pilot air screw all the way in and all the way out, but nothing seems to help. I have installed new pugs, and new K&N air filters. Also, I just put a new water pump shaft and impeller, balancer shaft, new piston rings and connecting rod bearings in. I don't know if any of this would cause the smoking and backfiring.
Can anyone help?
Ash
ashintrash is offline
post #2 of 6 (permalink) Old 07-16-2006, 04:57 PM
Once Banned
cegodsey's Avatar
Sounds like a timing issue. I'm not sure about the smoke. That could be something else. What color of smoke?
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 6 (permalink) Old 07-16-2006, 06:23 PM Thread Starter
well I haven't checked the timing yet, but I will do that shortly...
The smoke is white and smells heavily of gasoline. I think it has something to do with the fuel/air mixture and the fact that I put the K&N filters on... does that sound reasonable?
post #4 of 6 (permalink) Old 07-17-2006, 12:50 AM
Once Banned
cegodsey's Avatar
They say that you have to change jets if you do an ear shave, but just changing the filters to a diff brand wouldn't be that much different. Do you have to use the choke to start it? Could be flooding. Actually, that probably is the problem. Ever drive with the choke on? Idles OK, but no power and same symptoms. There's a guy on our Links page that is a carb guru. Might check out his website. Also, Fergy lives in Burnet, TX, which I understand is not far from Austin. You might PM him and maybe he can give advice or come look at it...
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #5 of 6 (permalink) Old 07-19-2006, 05:43 PM
fergy's Avatar
WiredGeorge lives in Mico TX and is a carb expert. He's the one on the links page.
How did this all come about? Did the bike run good and then suddenly go bad, or did you do some of the work on it and then it started smoking and running bad? I'm just curious. It sounds like it's getting way too much gas, like the choke is stuck in the on position. Crazy question, but you are turning the choke off aren't you? Push the choke lever away from you to turn it off... Stranger things have come up on here, believe me!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 6 (permalink) Old 07-20-2006, 06:08 AM
Been There.
Done That !!
Hope I don't do it again !
Gets ya a little worried when it's not runnin' right, then ya feel a little foolish once ya see the lever pointing at ya !!
