Idle adjuster part - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 09-13-2011, 05:41 PM Thread Starter
Idle adjuster part
Hello ,
I'm Phil from Belgium and have a kawa vulcan ( US model ) from 1985
I do have a problem , The cable to adjust the low and high Idle is broken and can't adjust it any more the cable is loose from the knob ,
I don't know if it is clear , But can any one help me to find thr parts knob and cable so that I can replace it ?
thanks for help
Phil
phgody is offline
post #2 of 8 (permalink) Old 09-13-2011, 06:23 PM
Git-R-Done!
AZ Kev's Avatar
Phil -
I would suggest looking on eBay - you can even follow the link from the Forum that takes you there (Vulcan parts on Bay, I think). I'm sure you can get an OEM one online, but it will cost you some serious $$$ I'm sure, as all that stuff does.
My other suggestion, if you lived in the States, would be craigslist - but I'm not sure if you have that over there. What about motorcycle junkyards? Are there any of those you could check? I have gotten a lot of great parts - cheap - through one we have here.
Lastly, you could try posting this question in the "Sell/Swap" section here on the forum. You'd probably have better luck that way.
Best of luck : )
AZ Kev
Arizona Kev
1989 VN750
7800 orig mi when purchased Jan 2011
Turned 11,000 mi Nov 2011
Saddlebags
Taillight relocation kit
Chad's highway peg mounts
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
Otherwise, all stock
"But it's a dry heat - like the inside of an oven"
AZ Kev is offline
post #3 of 8 (permalink) Old 09-14-2011, 12:35 AM
Well this site doesn`t even show a 1985 vn750, but here is a diagram for an `86:
https://www.vn750.com/forum/showthread.php?t=18899
Unfortunately neither this diagram or the carb parts diagram shows the idle adjuster flexible shaft you are looking for.
Is the shaft/cable broken in any way?
Or is the black knob just loose?
Is it possible to glue the knob back onto the cable?
Or fashion a new knob from epoxy like JB Weld or something similar?
post #4 of 8 (permalink) Old 09-14-2011, 10:46 AM
Roach's Avatar
I think you may have posted the wrong link Gordon.
If I remember correctly that cable is pretty much a rubber hose connecting the knob to the screw. Perhaps there is cable inside there, I'm not sure.
You can see it in one of my videos here.
http://www.youtube.com/watch?v=dyC7W...ailpage#t=726s
If it is just a tube you might be able to glue it back together like OlHoss had mentioned, or stick a new piece of tube in there and epoxy both ends.
EDIT:
Looking at that video again, there must be some kind of cable there. It is pretty stiff and makes a sharp corner.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #5 of 8 (permalink) Old 09-14-2011, 03:30 PM
Crobins365's Avatar
There's a rod inside the tube - it's threaded at the carb end and there should be a small spring on it. Sometimes the rod separates from the tube, so turning the knob just moves that plastic tube around - looks like it should be adjusting the idle, but isn't doing anything. If that's the case, try gluing the pieces together again.
C
Crobins365 is offline
post #6 of 8 (permalink) Old 09-14-2011, 10:53 PM
I have not had a good look at the idle adjuster on my bike, but thought it looked similar to the flexible shaft on a nut driver or socket extensions I have.
Can anyone find find it in the exploded parts diagram?
post #7 of 8 (permalink) Old 09-14-2011, 11:43 PM
Roach's Avatar
It's part 16021 in this diagram.
Street
Dirt
Roach is offline
post #8 of 8 (permalink) Old 09-15-2011, 12:49 AM
Hi all...New guy here as well. I have a 95 VN750 that I have owned for about 9 years. I had the same problem with the adjuster cable breaking. The cable is similar to a speedometer cable. It's coated with heat shrink, fused to the knob, and has a screw on the other end. I went to the dealer and they wanted $86 for this part, less spring. They actually told me that with a straight face.
I bought one for a ZX1100 on ebay for $10. It was longer than VN750 type and it had a different bracket. No problem. I put it in a vice and cut the heat shrink along the length of the cable. This allowed me to remove the bracket and put on the 750 bracket. I put the split heat shrink back on and then covered it with new heat shrink. The cable was a little longer so I had it exit out the right side of the bike. I put a slight bend on the bracket and was able to attach it to the side of the carb. It works great. Better than it did before. So bottom line is even if it is not the 750 part, you can still adapt other adjusters to fit.
Steve in CA is offline
