Vacuum Leaks - Seek & Find Tips - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 09-13-2011, 12:14 AM Thread Starter
OldHipWesTex's Avatar
Send a message via Yahoo to OldHipWesTex
While working on my '85 Vulcan 750 i suspected i had a vacumm leak between the carbs and the head intakes. I remembered a trick an old car mechanic showed me years ago on how to find these leaks on a car engine or motorycycle engines.
Find one of those small portable propane bottles everyone keeps around or get one from your local hardware dealer. I usually just turn the valve on the small propane bottle and let the gas flow. NO striker or cig ligter needed. With the enigne running as close to idle as one can get it to, place the nozzle end of the propane bottle around clamped off hoses or any where you suspect there might be an intake leak. If you come upon a leak the engine rpm will increase thus telling you that this is the location of an vac leak. Hope this is helpful!
Oldhip
OldHipWesTex is offline
post #2 of 8 (permalink) Old 09-13-2011, 01:20 PM
Papa Smurf's Avatar
It seems like it would work, but propane leaks make me leery. I would imagine a can of wd40 would do the same and your diagnosing would be much more pinpoint.
Papa Smurf is offline
post #3 of 8 (permalink) Old 09-13-2011, 07:06 PM Thread Starter
Have used this for years and never had a problem, but, have never used WD40 to find leaks either
post #4 of 8 (permalink) Old 09-13-2011, 08:40 PM
Concert connoisseur
wib714's Avatar
wd-40 would leave a mess, propane will not!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #5 of 8 (permalink) Old 09-13-2011, 09:27 PM
you can also use brake cleaner, carb cleaner or just about any flammable spray. If you are really lucky you have access to one of those cool ass smoke machines with the dyed smoke.
I remember reading somewhere that you could use a lit cigarette too, but I don't know how comfortable I would be with that.
post #6 of 8 (permalink) Old 09-14-2011, 05:00 AM Thread Starter
Adding a pack of cigs would drive the cost up
post #7 of 8 (permalink) Old 09-26-2011, 11:58 PM Thread Starter
After taking all the carbs off and all of the factory items attached to the intake system, im pretty amazed that the carbs have enough space to breath, especially after entereing the air filters,going down two narrow bottle necks, down the air box and then down two intake tubes to the carbs, lots of turns & twists here!! I suppose thats the reason folks do the "ear shave" thingie. Just a few thoughts runnin round in a riders head here today
If She Rides Good Then Keep Her - She May Be 27 Years Old But Shes As Wild As An 18 Year Old !
post #8 of 8 (permalink) Old 09-27-2011, 01:21 AM
If only it had 6th gear..
DavesVulster's Avatar
Yeah the airbox (Plenum,surge tank whatever) is quite a contraption isn't it? I saw pictures of one that was for sale fully assembled off the bike. Looked like an alien body part. Then you get to the actual little square chicklet intake holes in the ears themselves and wonder how does it perform as well as it does? I guess the chamber prob has some engineering for circulation and all that but I don't regret ditching mine.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
