Ear shave + rain = ??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 13 (permalink) Old 08-25-2011, 01:43 AM Thread Starter
Got a question for you folks with ear shaved bikes. I don't have the luxury of a garage, but semi-covered parking under the eave of the garage overhang. If rain would fall w/o wind, 90% of rain would miss the bike. Any wind would blow rain on the bike, soaking the K&N filters.
How does the bike run with wet K&N filters? How about driving in the rain? I've been caught out in the rain, sometimes hard driving rain, but with the protection of the ears minimizing water infiltration.
Considering ear shaving, but water is a great concern. I live in Texas so it's probably never going to rain again! I do ride her rain or shine, so do I do it?
Thanks
To Do List:
-T7 stator mod
-R/R relo
-MF Battery
-voltmeter
-ignition switch
-ACCT's to MCCT's
-LED brake & turns
-spline lube
Did I miss anything?
Kayakrazy is offline
post #2 of 13 (permalink) Old 08-25-2011, 02:22 AM
I dunno, I've ridden in some heavy crap; last time was all the way to Eureka Springs from Houston, and from Cleveland up to the other side of Shreveport it was solid rain. The rest of the trip the next day was the same way; as soon as I fueled up in Shongaloo, LA, it started, and didn't quit 'til the other side of Ashdown, AR. Intermittent heavy rain the rest of the way. No problems the whole way, as far as how the bike ran.
FWIW, my bike sits out in the weather, uncovered, fairly often, and I'm a year round all-weather rider. The Uni filters I use have never gotten rain soaked, in the 40+ thousand miles since I shaved the ears.
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #3 of 13 (permalink) Old 08-25-2011, 03:20 AM Thread Starter
Cool!
That's great to know, JD. What's a Uni filter? Have you coastered or marbled? And what are you doing up at this hour?! -jim
To Do List:
-T7 stator mod
-R/R relo
-MF Battery
-voltmeter
-ignition switch
-ACCT's to MCCT's
-LED brake & turns
-spline lube
post #4 of 13 (permalink) Old 08-25-2011, 03:02 PM
1) Uni PK-92 pod filters; Cycle Gear up on 10W, I think between Wurzbach and DeZavalla, should have 'em, around 40 bucks a pair
2) Coastered
3) <G> Cleaning bike parts; couldn't sleep. There were wierd noises on the roof; some kind of wet stuff in big drops. I think it was rain, but haven't seen any in so long I wasn't sure
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
post #5 of 13 (permalink) Old 08-25-2011, 05:28 PM
dirtrack650's Avatar
I use Emgo (K&N copies $10 each) with K&N filter oil in wet Washington State. I've ridden in rain, parked in rain, then rode home in rain w/o a problem. I've covered the pods with sandwich bags if I think they will get too wet (I do this when washing the bike too).
Like this: EMGO POD
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #6 of 13 (permalink) Old 08-25-2011, 06:49 PM
Roach's Avatar
I think the filter oil should repel any water that hits it while driving. But if it's a real concern you can always use a pre-filter.
Some of them are hydrophobic. Drycharger models are K&N's version.
I've used these kind of pre-fliters dirt biking in the dunes and they worked like a charm for dust.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #7 of 13 (permalink) Old 08-25-2011, 08:14 PM
If only it had 6th gear..
DavesVulster's Avatar
Absolutely do it. You'll love the response. I fabbed my own filter that sits up under the tank. Others have done similar with their ear shave mods so I thought I'd throw that option out there. Good luck.
dt
DavesVulster is offline
post #8 of 13 (permalink) Old 08-25-2011, 09:29 PM
As long as you use filter oil on them periodically they should not be letting any significant amount of water into your motor unless you physically pour water on them from a pitcher while the bike is running.
Keeping that in mind, a small amount of water, "moisture" would be more accurate, would not cause any problems anyway. Your more likely to have issues from water in your electrics.
post #9 of 13 (permalink) Old 08-25-2011, 11:39 PM Thread Starter
There's a shave in my future!
Well, that settles it. Gonna do it. Thanks everyone in the Vulcan community!
To Do List:
-T7 stator mod
-R/R relo
-MF Battery
-voltmeter
-ignition switch
-ACCT's to MCCT's
-LED brake & turns
-spline lube
post #10 of 13 (permalink) Old 08-26-2011, 01:22 AM
Ceal's Avatar
Like this: EMGO POD
Does it run well with those filters? Someone on here got pretty upset when I said I was looking into them, saying they just wouldn't work with our bikes.
Ceal is offline
