Idle adjustment - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 08-14-2011, 04:06 PM Thread Starter
Model A Guy
Jeff Barnes's Avatar
Idle adjustment
Can the idle adjustment effect coming back to idle quickly?
Throttle cables are adjusted correctly, and when the idle is set to 1000-
1100 rpm it takes too long to return to idle. If the idle is set lower it returns
like it should. This really effects riding and changing gears...
1992 model. Any suggestions? Thanks!
Jeff Barnes is offline
post #2 of 2 (permalink) Old 08-14-2011, 04:17 PM
If only it had 6th gear..
DavesVulster's Avatar
I would check for a vacuum leak. The rubber manifolds that fasten the carburetors to the engine, hoses etc.
DavesVulster is offline
