Carb Jet Question, Answers Welcome - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-22-2011, 06:23 PM Thread Starter
G3P0's Avatar
I have an 85 vn700, ears shaved, re-jetted, goat still in, considering removing it.
I had to get some spare parts for the re-build, got some 750 cylinders & pistons, will I need to re-jet again to use the 750 top end? I havent looked to closely at the carb or jets because they work great. My main reason for wanting the 750 top end is because I can't easily get head gaskets for the 700 and don't want to re-use the old ones, anyone? bueller?
85 VN700 Project Bike
Earshave
Mustang Seat
Custom grill cover
Busted Engine... removed, split, waiting on parts
Cleaning up & painting the rest
Parts still needed... wanted...
11" shocks, or one stock
Aftermarket exhaust... eventually
Extended forward controls or custom hwy peg mounts for my cramped legs...
G3P0 is offline
post #2 of 7 (permalink) Old 07-22-2011, 11:01 PM
If only it had 6th gear..
DavesVulster's Avatar
I don't think you will need to re-jet them. Just double checked the manual. Air cleaners are the same ( I know you shaved ) and the jets are the same numbers. Pretty sure the jetting has more to do with balancing the air/fuel ratio with the restrictions of the original air cleaners or in your case and mine with the ears gone, the size of the orifice on the carbs. An increase of 50 cc's is not a big enough change to effect that. It's like putting a Holley four barrel from a 305 V8 onto a 350. No changes need to be made except of course messin' with the idle mixture. Hope it goes together smoothly for you. I just cleaned and tested my floats and I'm going to reassemble everything tomorrow and hopefully be ridin' by mid morning and letting the nightmare of the past couple of weeks dissolve in the drone of the engine. Peace,
Dave
DavesVulster is offline
post #3 of 7 (permalink) Old 07-22-2011, 11:06 PM Thread Starter
G3P0's Avatar
Maybe I should start with this question.
Can 750 heads & pistons be properly installed on a 700 without modification? I saw a thread on this once but can't find it now.
This is a question for the engine thread I know, didn't want to start a new one on the same topic...
Earshave
Mustang Seat
Custom grill cover
G3P0 is offline
post #4 of 7 (permalink) Old 07-22-2011, 11:17 PM
Probably but not sure. take a look at the online manual below. There's a section called my rides and you can enter more than one bike to compare part numbers and diagrams. Maybe that will help some.
http://www.cheapcycleparts.com/model...semblies/73162
post #5 of 7 (permalink) Old 07-22-2011, 11:24 PM Thread Starter
G3P0's Avatar
Double post, lag...
Earshave
Mustang Seat
Custom grill cover
G3P0 is offline
post #6 of 7 (permalink) Old 07-23-2011, 10:54 AM
I'm assuming you mean cylinders, not heads; heads should be the same on either engine. The 750 is essentially a bored out 700, and in fact, the only difference in the cylinders is probaby the liner used.
In other words, the only difference in the two engines is the cylinder bore. 750 cylinders and pistons can be used on the 700 case with 700 heads or 750 heads.
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #7 of 7 (permalink) Old 07-23-2011, 03:46 PM
Chucklehead
dragon159's Avatar
X2 ^ as a testament the original engine in mine (when I got it) was a 700 bottom with 750 jugs and heads. ran fine but the "hacks" that put it together messed up the base gaskets and so it was leaking all over the lower end and onto the rear tire .....
Glad I changed it.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
