Air Filter Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 07-21-2011, 10:06 PM Thread Starter
Big Dumb Viking
asbrand's Avatar
Send a message via AIM to asbrand Send a message via MSN to asbrand Send a message via Yahoo to asbrand
Air Filter Question
My bike still has the original "ears" for now.
My question: How often should you replace the filters in them? Or, can they be cleaned and re-used, and if so, how?
Thanks ahead of time!
-Az
http://www.asbrand.com
1989 Kawasaki Vulcan 750
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
RAM GPS Mount w/Garmin GPS
Cigarette Lighter Power Adapter
Saddlemen's Classic Explorer Seat
Pro-Tac Driver's Backrest
LED Tail Light
LED Rear Turn Signals
Luggage Rack
Storage Trunk
Engine Guard w/Highway Pegs
Radiator Grill Cover
Turn Signal Relocation Bracket
Saddlebags
Floorboards
asbrand is offline
post #2 of 20 (permalink) Old 07-21-2011, 10:44 PM
Member? ... check.
ZCraggRatt's Avatar
Hey Asbrand,
Our air filters are cleaned and conditioned just like a lot of lawn mower engines.
First, clean the filter elements in a mild detergent. Then rinse out and let dry. After that, completely soak the elements in non-detergent 30 weight engine oil. Work the oil in to the filter pores well. Then, squeeze as much of the oil out as possible, and then re-install.
The filter elements get quite delicate with age, so be careful to avoid damage with the cleaning and squeezing out. You definately should not use the wringing method.
Hope that helps.
Later,
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine - 10k mi.
Done: Coastered, .020 ign., Iridiums, VM, Plexistar II, MCCT's
Next: LED's
Will Do: MOSFET, Horns, Shave(maybe)
ZCraggRatt is offline
post #3 of 20 (permalink) Old 07-21-2011, 10:50 PM
If only it had 6th gear..
DavesVulster's Avatar
I'm pretty sure the original elements can be washed but very gently. They rip if you look at them wrong, especially if they haven't seen daylight in a while. And I read oiling them should be done very spearingly. Too much will screw up your air/fuel ratio and ruin the filter element. There's a recommended oil that is best for them but... I can't remember. Sorry for the half info. I'll go peek around and update this if I find it.
DavesVulster is offline
post #4 of 20 (permalink) Old 07-21-2011, 10:52 PM
Originally Posted by ZCraggRatt View Post
Hey Asbrand,
Hope that helps.
Later,
Love this site. Never saw more responsive people so willing to help
post #5 of 20 (permalink) Old 07-22-2011, 12:40 AM
Just checked the Clymer manual and they recommend replacing the foam filters every 15,000 miles or after 5 cleanings, OR every 2 years.
That seems to indicate the filters should be cleaned and re-oiled every 3,000 miles, or with every oil change.
Clymers also says the filters can be cleaned with a mild high flash point solvent, then rinsed out with detergent and water, then clear water. Something like kerosene or paint thinner should be ok.
I cleaned the K&N filter on my car with just hot soapy water a few months ago. It was quite dirty and required a couple of spray applications of *Simple Green*, along with 3 changes of hot water and detergent before it was clean enough to satisfy me.
The Clymer manual describes the 30 weight oiling method that ZCragRatt mentions, but others have warned that this method makes it way too easy to over oil the foam, restrict air flow, and cause a rich mixture. Special filter oil is available at motorcycle dealers, and I recommend using that or the K&N filter oil that I used on my car filter.
ZCR is right about not wringing or twisting the filter elements.
Press the filter between layers of shop cloths or paper towel on a flat surface to absorb any excess oil.
I`m sure more complete directions are in the online service manual on the TOC site or the searchable version on Kanuck69`s sig line.
post #6 of 20 (permalink) Old 07-22-2011, 02:36 AM Thread Starter
Big Dumb Viking
asbrand's Avatar
Thanks for the info guys. One of the reasons I love this site.
-Az
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
LED Tail Light
Luggage Rack
Storage Trunk
Saddlebags
Floorboards
asbrand is offline
post #7 of 20 (permalink) Old 07-22-2011, 02:25 PM
ifixf18s's Avatar
After oiling I squeeze mine out with a clean rag to soak up as much oil as I can.
ifixf18s is offline
post #8 of 20 (permalink) Old 03-01-2012, 08:25 PM Thread Starter
Big Dumb Viking
asbrand's Avatar
I know this is an old thread...but I just now, tonight, got around to opening up my air boxes. I was surprised to find that I didn't have the original filters. Evidently, someone had put K&N ones in there.
Still need to clean them...they're pretty filthy.
Do the K&N ones need to be oiled like the stock foam ones?
-Az
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
LED Tail Light
Luggage Rack
Storage Trunk
Saddlebags
Floorboards
asbrand is offline
post #9 of 20 (permalink) Old 03-01-2012, 08:36 PM
I always thought all KN filters had to be oiled. But they , of course , reccomend their own filter oil. You can buy it in a spray can.
post #10 of 20 (permalink) Old 03-01-2012, 09:14 PM
I too believe all K&N filters need to be oiled.
I have a K&N filter on my car that I cleaned and oiled a few months ago.
Using their red colored oil made it easy to see when the filter was sufficiently and evenly oiled.
