Hose Locations After Carb Rebuild - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-21-2011, 03:19 AM Thread Starter
Finished a carb rebuild today & I have 2 hose routings ? I did look in the manual & parts schematics.
1.On the bottom of the fuel level sending unit, there appears to be a hose barb. I didn't see a hose that connected to it when I removed the tank. Is there one?
2. The center petcock hose goes to the left hand carb correct? I assume this is a vacuum hose to open the petcock.
thanks guys
Dean W is offline
post #2 of 2 (permalink) Old 07-21-2011, 01:55 PM
1. "The bottom of the fuel level sending unit" .... you're going to have to be more specific because I have no idea what you're talking about. There should be no hoses on the actual bottom of the carbs, though. Many members have had a lot of trouble with the vent lines that lead into the right ear. They both feed into a T before feeding again into a spot behind the right ear. This might be what you're talking about.
2. You are correct in your assumption that the center petcock hose is a vacuum hose. It connects to a nipple on the left side of the left carb and will give you serious idle issues if it's not air-tight.
vulcanpower is offline
