Stuck Idle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 07-14-2011, 10:29 PM Thread Starter
Stuck Idle
hey guys, I had an unusual ride home today and wanted to see who else had experienced this. Bike is a 03 w/ 7K on odom. Have never had any issues with carbs before this...other than replacing the idle adjuster. While riding home, the idle was very slow to come down after letting off, and while accelerating the idle would stay at RPM while shifting. I was thinking the cables may need some lube, but when the bike is not running, the throttle snaps back fine. Maybe a vacuum leak?? Any ideas are appreciated. Thanks
IndyVN is offline
post #2 of 8 (permalink) Old 07-14-2011, 10:56 PM
Crobins365's Avatar
My money's on a vacuum leak. I think the tried and true method is to run the bike and spray WD40 or similar around the various boot connections - a sharp increase in idle will tell you where your leak is.
C
Crobins365 is offline
post #3 of 8 (permalink) Old 07-15-2011, 01:52 AM
I had this happen to me a few weeks ago. I still have no idea why.. If I turned off the bike it would run right but as soon as I gave it gas it would stay up around 3k.. Got her home and decided to look at it the day after and couldn't get it to do it again.
1995 VN750 (SOLD)
05-06 CBR600 R/R
ACCT>MCCT mod
engine guard w/HW pegs
Tires, 230's (170/110)
Smaller blinkers
Driving lights
Pickup coil mod
Speedo delete
mirrors w/reverse mount
Black grips
2000 Buell X1 Lightning
Carbon fiber fender F&R
Carbon fiber fly screen
Carbon fiber race intake
Works Shock
V&H Muffler
SS headers
Roncgizmo is offline
post #4 of 8 (permalink) Old 07-16-2011, 02:56 PM
Check out the vacuum hose coming off the left carb and into the petcock. These seem to come off very easily. Also try the opposite side as well. Might be an easy fix.
vulcanpower is offline
post #5 of 8 (permalink) Old 07-27-2011, 05:07 PM
rev it up's Avatar
just wondering if Indy got this problem solved ?,,Reason being,i got the same problem now . checked the vacumm pipes best i could but to no avail. it still runs ok,,but very annoying during gear shifts,and stopping at junctions. Grrrrrr.
AGEING IS INEVITABLE,,MATURING IS OPTIONAL
VN 750 A8 1992.
27000 miles.
Imported from California
to UK in 1996.
New for 2012.
new filters(foam type)
replacement shocks(MDI)
Iridium plugs.
AGM battery(platinum)
brake pads(Kyoto)
(All on and running)
rev it up is offline
post #6 of 8 (permalink) Old 07-27-2011, 11:01 PM
Freedom's Avatar
Have you guys been adjusting the idle at all, with the knob?
Bike is sold, thanks for the help guys. Ride safe.
Freedom is offline
post #7 of 8 (permalink) Old 07-28-2011, 01:22 PM
rev it up's Avatar
Not me,,,,mine idles at 1k. But if i rev it,it takes too long to rest back at 1k. I tried messing with the idle adjuster but it makes no difference. thanks.
VN 750 A8 1992.
27000 miles.
to UK in 1996.
New for 2012.
Iridium plugs.
brake pads(Kyoto)
post #8 of 8 (permalink) Old 08-17-2011, 11:44 AM
I have a 2004 and its doing the same thing. It seems to work good until it gets warm and then it takes a while to drop down to idle. Sometimes it will drop to about 1500rpm and stay there and never return to idle. When its cold its almost the opposite. They idle barley makes it to 1100rpm and have to run the choke alot longer thatn I should
Blazchasr is offline
