Piston Rings - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 07-04-2011, 11:01 AM Thread Starter
REDRIDER
danield's Avatar
Piston Rings
I have a 2006 Vulcan 750 that has 16,000 miles. Never really had a problem until last month. I set it up for the winter in my garage. Added gas and a stabalizer (sea foam), change the oil and put the battery on a trickle charger. Yes it got cold this year in Arkansas. I clean the plugs, changed the oil, drain the carburators and gas tank and put in new gas. When I tried to start, the engine sputtered for a few seconds then would not start. I took it to my local Kawasaki dealer. He checked it out and said the compression was bad. Sprayed oil in and compression was higg but then started going down. He said I needed to rings. Anyone have a simplier solution to freeing the piston rings (if that is the problem) without spending $800-$1000 to fix?
danield is offline
post #2 of 8 (permalink) Old 07-04-2011, 02:49 PM
ifixf18s's Avatar
There is seafoam thats in a spray can with a spray tube like WD-40. Wonder if that would work if you took the plugs out and sprayed it in the cyl's
ifixf18s is offline
post #3 of 8 (permalink) Old 07-04-2011, 08:34 PM
Clint '89
ourselfish's Avatar
Rebuild it your self It could be a fun challenge.
"Someone once told me that watching the birds fly, made them want to go on a journey."
ourselfish is offline
post #4 of 8 (permalink) Old 07-05-2011, 09:12 AM
flitecontrol's Avatar
I'd have someone else double check the compression. A well maintained bike with that few miles shouldn't have compression issues.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #5 of 8 (permalink) Old 07-05-2011, 10:06 AM
JM2001's Avatar
X2 You should have noticed any problems before you put it in storage. Our bikes here are in storage about 6 months a year, with no problems from that.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 8 (permalink) Old 07-05-2011, 11:31 AM Thread Starter
REDRIDER
danield's Avatar
piston rings
I bought a can of the sea foam(spray). I will try that first. I need to get a tool to test the compression myself. The bike was running fine before I set it for the winter.
danield is offline
post #7 of 8 (permalink) Old 07-05-2011, 03:01 PM
Lots of testers, both new and used, on ebay. http://shop.ebay.com/i.html?_from=R4...All-Categories
"Black Beauty"
Old Blue
post #8 of 8 (permalink) Old 07-05-2011, 03:23 PM
rev it up's Avatar
X3. Piston rings do not wear while in storage. you normaly would have had excessive smoke issues before storing if it was rings,,as said by the other two,,i'd investigate further before accepting its a ring issue. good luck.
rev it up is offline
