pod filters? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-03-2011, 11:41 PM Thread Starter
pod filters?
I am planning on doing the ear shave to my VN700 and was wondering if someone could tell me what diameter/size pod filters i need? thanks for any info
hoggs750 is offline
post #2 of 7 (permalink) Old 07-04-2011, 12:09 AM
KidChaos's Avatar
http://06vn750.blogspot.com/
All the info is listed here.
Good Luck
KidChaos is offline
post #3 of 7 (permalink) Old 07-04-2011, 04:56 AM
Heading to the DARKSIDE!
BRET H's Avatar
I used Uni filter pods kit PK-92 that I bought off of Amazon.com They fit perfect. There rubber boot size is 2 1/8" - 2 1/4"
BRET H is offline
post #4 of 7 (permalink) Old 07-04-2011, 07:06 AM Thread Starter
thanks,Ill post the outcome
hoggs750 is offline
post #5 of 7 (permalink) Old 07-24-2011, 06:22 PM
soooooo...
1985 Vulcan 700 rider here.
Here's what i got. Removed stock ears/filters/air box (under gas tank). My exhaust...muffler is off. I have taken the stock exhaust pipes off...cut them in half and put them back on.
I was reading that link posted above about the "ear shave"....Has anyone here done the same thing to their bike that ive done with mine?
i wanted to know the jet size you used. Im currently thinking of extending my exhaust back to the center of the wheel. Just straight pipes basically.
ALSO. is there any difference (that is worth it 100%) between KN pod filters, or some cheap ones off ebay?
ANY TIPS WOULD BE HELPFUL!
PS> Im also about to tackle the following myself : Stator, R/R, Clutch, oil/filter, carb clean, rejet. The bike has been lowered, and hardtailed. rustbucket is her name.
Tips on those projects would help too! thanksssss
Dorko is offline
post #6 of 7 (permalink) Old 07-24-2011, 06:42 PM
Originally Posted by Dorko View Post
soooooo...
ALSO. is there any difference (that is worth it 100%) between KN pod filters, or some cheap ones off ebay?ANY TIPS WOULD BE HELPFUL!
The K&N filter gives more dirrect air excess into the carb openning than the emgo pod filter. The openning that works the needle by air flow is located up at the top of the carb openning. The emgo filter gromet covers some of the air passage and the carbs do not operate properly.
This are the filters that I was directed to use. K&N rc-2340 and at 1961' alivation I used 40 pilot and 140 main 2 shim under each needle.
post #7 of 7 (permalink) Old 07-31-2011, 10:02 AM
ear shave filters
I used k&n #K&N rc-2340 from Amazon the price was the best and they fit perfectly -- if you raise the back of the tank 1/2 in.
hegman is offline
