From carb drops offline at idle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-03-2011, 01:35 AM Thread Starter
Sometimes (increasingly often) at idle the front carb does not do much. If I pull the front plugs there is no change in RPM. I can actually pull the rear plugs and the bike will idle on the front but at a much lower RPM than if I pull the two front plugs. It sounds like a carb sync issue except that it doesn't happen every time. In fact when I drop down to idle it will initially "stop" at the higher RPM typical of both cylinders firing then within a second or two further drop down to the RPM typical of the front cylinder not doing much.
-Robert
RobertGary1 is offline
post #2 of 4 (permalink) Old 07-03-2011, 01:36 AM
try the carb sync and go from there.
post #3 of 4 (permalink) Old 07-03-2011, 02:12 AM Thread Starter
Can I do the carb sync with a generic vac gauge or is there a better procedure?
post #4 of 4 (permalink) Old 07-03-2011, 10:55 AM
Crobins365's Avatar
http://www.ppcflyingforums.org/forum...read.php?t=235
http://www.powerchutes.com/manometer.asp
Here are a couple of links on how to make your own manometer. If you can find the right inner diameter tubing (7/32, I think), you're in business.
Before buying all of these expensive parts LOL, check your spark plug wires and make sure you don't have a split in them somewhere. You could be grounding out on one of the wires intermittently, leaving that plug without power.
C
Crobins365 is offline
