Throttle cable question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-24-2011, 05:03 PM Thread Starter
six6six's Avatar
Are both throttle cables the same? My bike only had the pull cable on it, not the push cable. Reason i ask if they are both the same, on ebay it doesn't specify if they are selling the push or pull cable, so i am assuming they are both the same?
six6six is offline
post #2 of 11 (permalink) Old 06-24-2011, 07:14 PM
Stones750's Avatar
In the parts diagrams there is different part numbers for them but the only difference I can tell is one comes with the little fitting that screws into the bottom of the throttle grip housing it basically holds the two cables in place.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
post #3 of 11 (permalink) Old 06-24-2011, 11:53 PM
the push and pull cables are different lengths.. can't remember which one is longer though
post #4 of 11 (permalink) Old 06-25-2011, 01:09 AM Thread Starter
six6six's Avatar
Ill just look for one on ebay with out the retainer, that should mean its the push cable...
six6six is offline
post #5 of 11 (permalink) Old 06-25-2011, 05:52 PM
here is a complete set
post #6 of 11 (permalink) Old 06-25-2011, 06:56 PM
KidChaos's Avatar
I recently had this issue. I needed a push cable and figured I would replace both. I bought a push and pull from Motion pro, but from two different websites, limitations in stock.
After some careful examination,. they sent me the wrong push cable, and I checked the motion pro website. They use the same cable for both on our bikes. This is because they have a pretty wide adjustment range on their cables.
So, long story short, I tried using the motion pro cable as my pull (go), and my stock pull as my push (don't go). Didn't work, stock pull was too short to be a push cable. When I reversed them and kept my stock pull as a pull cable and used the Motion Pro "pull" cable as a push, it all fit perfectly (I just had to remove the bracket that holds the two cable together from the Motion Pro cable.
So in summation, the stock cables are different lengths, slightly. It is hardly noticeable. But the Motion Pro cables for push and pull are the same length and are completely interchangeable. I recommend purchasing from jakewilson.com.
I would stay away from Cheap Cycle Parts for this order as they are the ones that sent me the wrong cable, and it took twice as long to get it as the one from Jake Wilson.
Hope this helps.
KidChaos is offline
post #7 of 11 (permalink) Old 06-25-2011, 11:26 PM Thread Starter
six6six's Avatar
Just bought a cable off ebay, one without the retainer.
six6six is offline
post #8 of 11 (permalink) Old 06-26-2011, 10:41 AM
Cables
Dea six6six
I checked my bikes cables and both cables are pull one opens each carb and a spring closes the carb. I believe the reason for the 2 cables is to sinc them.
Hegman
hegman is offline
post #9 of 11 (permalink) Old 06-26-2011, 11:19 AM
KidChaos's Avatar
Originally Posted by hegman View Post
Dea six6six
Hegman
This is not accurate. One cable opens the throttle body which feeds fuel to the carbs. The other cables pulls on the opposite side of the same lever - hence a push/close cable.
To get a better understanding of how they work it helps to open up the housing on your handlebar where the run switch is. Then watch how the cables move as you twist the throttle.
EDIT**
If you don't have a push cable the throttle will still close, but in my experience it can be sluggish and hang open for a couple of seconds, resulting in a revving engine for a few seconds after you let off the throttle. This is the condition I bought my '91 in and led me to believe that my carbs needed a good cleaning. When I noticed the broken push cable and replaced it the problem went away instantly
KidChaos is offline
post #10 of 11 (permalink) Old 06-26-2011, 03:44 PM Thread Starter
six6six's Avatar
Maybe missing the push cable could be the reason my bike is firing on one cylinder at idle... hmm
six6six is offline
