Ear shave crankcase filter Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-22-2011, 12:12 PM Thread Starter
Stones750's Avatar
Hey guys I have my ear shave and rejett finished except for my crankcase filter. I bought the emgo crank filter but Im trying to figure out the best way to hook it up to the hose off the front cylinder. I have some extra fuel hose but wanted to see if anyone has any pointers. Any help is appreciated.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
post #2 of 6 (permalink) Old 06-22-2011, 12:40 PM
Fire Axe Man
run the hose to desired location and somewhere you can fasten it, zip tie, bolt or so on... the attach your filter... it needs to be above the motor near bottom of gas tank to help keep oil down...
Just can't leave well enough alone...
86 vn750
Ears Shaved
Custom Exhaust
Custom Seat
Hardtail 3 1/2" drop rear
Custom turn signals
15" apes
Custom grips
Custom forward controls
Custom paint
many more mods to come
Mike23Impala is offline
post #3 of 6 (permalink) Old 06-22-2011, 12:42 PM
Scootergptx's Avatar
In VoIPDoc's write up, he had this link and the last pic shows he mounted his up by the gas tank bolt. Looks good too.
Global warming? So what if my kids never see a polar bear. I never saw a dinosaur and I'm ok.
Scootergptx is offline
post #4 of 6 (permalink) Old 06-22-2011, 12:50 PM Thread Starter
Stones750's Avatar
Thanks for the tips guys! I found out my problem in the photo lol I need to find another section of hose similar to the breather tube.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
post #5 of 6 (permalink) Old 06-22-2011, 12:51 PM
clock152's Avatar
to attach the hose to the crank case hose.. you can just slide the fuel hose into the crank case hose and use a small hose clamp to hold it on... some have even used a pipe attached to the fuel hose and slid that into the crank case hose and then clamped it... a bit more secure that way and not much chance of leaking.
clock152 is offline
post #6 of 6 (permalink) Old 06-22-2011, 02:07 PM Thread Starter
Stones750's Avatar
Got her all patched up lol a small peice of coolant hose I found layin around at work was all I needed. I tried to use a peice of fuel line at first but it was way to small (same stuff that is used for carbs) One more "to do" crossed off the list! thanks guys!
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
