the air mix screws - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-04-2011, 01:15 PM Thread Starter
darein40's Avatar
the air mix screws
ok people this might sound dumb ...but where can i find the air mixture screws on my 95 vulcan it does have the ca emissions. i would like a picture if anyone has one. also is there a adjustment for the coaster enrichment.i am having back fire issues.
darein40 is offline
post #2 of 4 (permalink) Old 06-04-2011, 01:25 PM
KidChaos's Avatar
They are on the carbs. One on each side. Covered by a little metal cover. There are a lot of threads explaining this better than I can and that have pics. Perhaps search air mix screws or wait till someone else chimes in.
KidChaos is offline
post #3 of 4 (permalink) Old 06-04-2011, 01:35 PM
Does this picture help?
https://www.vn750.com/photopost/showp...to=681&cat=548
The screws are under a metal cap that needs to be removed.
Drill a tiny, shallow hole and pop the cap off with a pick or awl.
Be careful, don`t go deep with the drill bit, or you will deform the screw head.
I can`t find any reference to an adjustment for the coasting enrichener. Just this service advice.
Check the cover for damage.
Make sure the vent hole in the cover is clear.
Check the diaphram for tears or cracks.
Hope this helps.
post #4 of 4 (permalink) Old 06-04-2011, 03:02 PM
A search on this site would have revealed a dozen pics...Look at post #16 here
VoIPDoc is offline
