Sitcking choke plunger - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-02-2011, 10:11 AM Thread Starter
Git-R-Done!
AZ Kev's Avatar
Sticking choke plunger
Ok all, quick and hopefully easy question :
I have a sticky choke plunger, on the left side, and I am wondering if anyone out there has any kind of quick and dirty remedy? My thought was to just see if I can't get some WD-40 or some other lubricant on it using the handy dandy long straw that comes with it to get it right in that tight spot.
I want to make sure that it won't cause any unforeseen issues before I do it though. Currently, I just take a key or little screwdriver and 'manually' push it back in any time I use the choke. But when it gets cold(er) this winter, that is going to be a real pain.
Any thoughts/ideas/revelations are appreciated
AZ Kev
Arizona Kev
1989 VN750
7800 orig mi when purchased Jan 2011
Turned 11,000 mi Nov 2011
Saddlebags
Taillight relocation kit
Chad's highway peg mounts
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
Otherwise, all stock
"But it's a dry heat - like the inside of an oven"
AZ Kev is offline
post #2 of 5 (permalink) Old 06-03-2011, 11:19 AM Thread Starter
Git-R-Done!
AZ Kev's Avatar
No advice on this at all? Not even a "Yeah, of course that's what you should do dummy!"
C'mon now - if the question is that dumb, SURELY one of you should have jumped on it ; ) Or perhaps no one else out there has ever experienced this, which would seem a little hard to believe, but I guess stranger things have happened.
Arizona Kev
1989 VN750
Saddlebags
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
AZ Kev is offline
post #3 of 5 (permalink) Old 06-03-2011, 11:37 AM
flitecontrol's Avatar
Never had the problem, but recently learned that WD-40 leaves a residue that over time gets sticky. So if you decide to lube the plunger, might want to use something else.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 5 (permalink) Old 06-03-2011, 12:49 PM
Joem's Avatar
Mine does this sometimes. I just lean down and push it back in with my finger. I recently sprayed a little light penetrating oil on the plunger and it improved quite a bit.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #5 of 5 (permalink) Old 06-03-2011, 12:50 PM
I'd spay it with cable lube.... If you have some in the spray can.
Carb cleaner followed by white lithium grease in the spray can.
Shouldn't the choke lever/cable be pulling it up and down ?
