popping back fire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-01-2011, 12:49 PM Thread Starter
darein40's Avatar
popping back fire
i have a 95 vulcan and have a lot of popping on decel.but when i run it with the choke on it dont pop at all. any thoughts what this could be related to.
darein40 is offline
post #2 of 7 (permalink) Old 06-01-2011, 01:06 PM
I am having a similar issue with my 05. I recently ran 93 through it, and on decel the rpms would spike up, backfire, and slowly return to normal rpms. I was told it was bad gas, and some users on the forum said our bikes needed 87. I drained the gas, filled it with 87 and a tad of seafoam, and she is running at about 85%... as aposed to the 65% before!
Gas would be the first place I would inspect. Good luck!
shoman is offline
post #3 of 7 (permalink) Old 06-01-2011, 01:47 PM
do a search for 'marbling' and/or 'coasters'............
dariv is offline
post #4 of 7 (permalink) Old 06-01-2011, 02:07 PM
Welcome to the Vulcan madness darein40.
Vulcan Verses on popping, backfiring, coastering or marbling:
https://www.vn750.com/forum/showthread.php?t=1081
post #5 of 7 (permalink) Old 06-01-2011, 04:06 PM
Yes, stick with 87 octane gas, that`s what the vn750 was designed for.
Higher octane gas is ONLY required when the engine needs it to avoid pre-ignition or "knocking".
The higher octane is designed to be HARDER TO IGNITE, so will often actually run worse and dirtier in the vn750.
post #6 of 7 (permalink) Old 06-10-2011, 09:55 AM
Hey guys just to update ya, the popping, rpm spikes was all due to a loose neg cable connection on the battery... doh!! lol She runs like a champ now and only takes 87
shoman is offline
post #7 of 7 (permalink) Old 06-10-2011, 05:35 PM
Don`tcha love it when the fix is easy and no cost?!
