Ear Shave Procedure - Enjoy! - Page 34 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 14Likes
post #331 of 343 (permalink) Old 07-12-2018, 11:40 PM
Location: southern, western, middle Tennessee backwoods
Originally Posted by calebj View Post
Here's a PDF of Phil's original writeup:
https://drive.google.com/open?id=0B0...WZrckJXYWtFNUk
Here's a simplified/condensed version with the essentials. Might be a little easier to step through. Let me know if it needs any corrections:
https://drive.google.com/open?id=0B0...W91UHNHZEthOFE
Both have pictures embedded.
Just digging this out of the threads and making it apparent for the present time in case someone is interested.
calebj likes this.
"I need yo clothes, yo boots and yo motocycle."- Uncle Bob
roadpouring is offline
post #332 of 343 (permalink) Old 08-25-2018, 03:42 AM
Do you need to get different jets and the needles if you do the ear shave?
Trey2irwin is offline
post #333 of 343 (permalink) Old 08-25-2018, 10:46 AM
Not if you still have the stock exhaust. The bike does run lean so some have seen benifits going with larger jets, but many are still running stock jets with no problems (with stock exhaust)
post #334 of 343 (permalink) Old 05-02-2019, 12:38 PM
Jason Pittenger's Avatar
Originally Posted by Tedrowcranberry View Post
Thank you so much for posting this! It is still being used! I just finished my earshave and degoat on my 2001 vn750. Here's what I came up with! I also stripped the paint and repainted. First post to vn750.com!
Before and after:
Drop a couple of these badges on your tank. They will look great next to the blue!
https://www.amazon.com/Motorcycle-Em...s%2C137&sr=8-3
Completed modifications:
Planned modifications:
Jason Pittenger is offline
post #335 of 343 (permalink) Old 06-19-2019, 03:59 PM
MSattler's Avatar
Does anyone still have the .PDF? Also, is there a new source for the coasters?
MSattler is offline
post #336 of 343 (permalink) Old 06-19-2019, 04:13 PM
calebj's Avatar
https://www.vn750.com/forum/22-carbs...ml#post1059705
Coasters are available on eBay:
https://www.ebay.com/itm/332154980214
For others down the road, if that link is dead just go to eBay and search for 'VN750 smog plate'.
MSattler likes this.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #337 of 343 (permalink) Old 06-19-2019, 04:16 PM
Look for a very recent sticky post in the general discussion section, I think earshave is in there.
This one: https://www.vn750.com/forum/11-vn750...ne-vulcan.html
Ebay usually has coasters, emissions block off plates. It's the same plate for several Kawi bikes. Post what you find and someone can tell you if it's right. Some of us have made our own, there's not a lot of pressure behind the reed box..
post #338 of 343 (permalink) Old 06-19-2019, 04:39 PM
MSattler's Avatar
I appreciate it! *edit* Thank you for the links! I got the owner's manual, the service manual, and the mods link. You guys are saints
MSattler is offline
post #339 of 343 (permalink) Old 09-08-2019, 09:39 PM
2003 Vulcan 750/Sidecar
Hench's Avatar
Ouch, Spockster! Mea culpa!
Dang if I didn't leave the "ear shave" out of the "complete" PDF. Probably the most common mod made.
It shall be added.
Thanks!
2003 VN750
Velorex 562 sidecar w/trunk
2-wire mod
Headlight power switch
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
Voltmeter relay wired
Coils direct wired w/relay
handicap mods:
extended foot shift
heel shifter
extended brake pedal
Hench is offline
post #340 of 343 (permalink) Old 10-14-2019, 03:52 PM
Mike Peek's Avatar
I keep reading about the photos of this procedure, but I don't see any? Am I just too new to know how the site works?
Mike Peek is offline
