Pulling carbs, removing CA Emissions, Ear Shave...need help please - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-17-2011, 10:29 PM Thread Starter
So I've tried all I can without pulling the carbs to un-stick my floats, but it just ain't happening. You can read what I have gone through at my prvious link here https://www.vn750.com/forum/showthread.php?t=18121
So I want to take out all my CA Emissions, as I've read that will give me much more room to pull out and work on the carbs. Last time I pulled the carbs, it was such a pain, especially with that Surge Tank/Cannister in the way. I've read that is a nightmare to remove...good times.
Does anyone know of a post where I can get some detailed explanation on how to remove my CA Emissions junk, and hopefully some pictures too???
I'm also going to do the ear shave, and wanted to know if there is a full kit I can purchase? I read in the VERSES forum about a kit, but I also read that company went out of business. If there is NOT a kit out there, does anyone have all the parts PN's and a link to a thread with a description on what to do?
Thanks for your help...it's awesome that there are so many people out there with this bike.
1993 VN750 stock
knicol is offline
post #2 of 10 (permalink) Old 05-17-2011, 10:46 PM
No kits!
Parts:
1 Mikuni Needle Shims Item# Price: 009-396 $6.95
2 Keihin 99101-393 Main Jet Size: 142 $13.90
2 n424-22 Pilot/Slow Jet sizes: 42 $13.90
I purchased these from: http://www.pjmotorsports.com/keihin-jets.html
2 Emgo Crank Case Filter $14.95 each
I purchased these from: http://www.phatperformanceparts.com/...ode=14%2D20900
You don't NEED these but they look good.
2 Coasters $31 pair
I purchased these from: http://www.shermscycleproducts.com/coasterpage.html
Detailed procedure coming soon!
VoIPDoc is offline
post #3 of 10 (permalink) Old 05-17-2011, 11:05 PM
remove the reed valves and install coasters. Remove vacuum valve. remove vacuum line from right carb. Plug right carb vacuum port. There are two tubes at the base of the gas tank: remove the one on the right side and plug the port at the tank. remove the canister and related crap from under battery tray. Vent left side of gas tank to free air via rubber tube and let it hang unobstructed behind trans and make sure the end can't get blocked.... that's about it..........
dariv is offline
post #4 of 10 (permalink) Old 05-18-2011, 06:32 PM Thread Starter
Thanks for the info...I was all set on doing this mod and removing all my CA Emissions...then I read other threads where they say "if you are NOT in CA you can do the mods".
I am in CA, but we don't need to get the motorcycles tested for Emissions, unless that is something new. If there is no testing, is there an issue I should be aware of if I do remove all my Emissions junk?
1993 VN750 stock
knicol is offline
post #5 of 10 (permalink) Old 05-18-2011, 06:45 PM
... If there is no testing, is there an issue I should be aware of if I do remove all my Emissions junk?
Yeah, your bike will run better, look better, and be much happier............
dariv is offline
post #6 of 10 (permalink) Old 05-18-2011, 11:01 PM Thread Starter
haha...thanks "dariv"...yeah, I didn't think there would be an issue, but I read a post from a guy in Arizona that was talking about their strict emissions and him not being able to do the Ear Shave...I know California has the strictist emissions, and we don't check bikes...and everything I've read would be for new bikes being tested...not my old '93.
Cool...so I think I'll go ahead and rip it all out!!!
1993 VN750 stock
knicol is offline
post #7 of 10 (permalink) Old 07-11-2019, 11:03 PM
PlanetVulcan510's Avatar
What’s up bro. I’m doing the same to my 04 Vulcan. Just wondering if it worked out ok for you.
PlanetVulcan510 is offline
post #8 of 10 (permalink) Old 07-13-2019, 11:17 AM
Planet guy...
This thread is 8 years old and he hasn't visited since 2014. So your odds of getting a reply are very slight to none.
You can go to a members profile and see when their last post was BTW
post #9 of 10 (permalink) Old 07-26-2019, 03:49 PM
So I've tried all I can without pulling the carbs to un-stick my floats, but it just ain't happening. You can read what I have gone through at my prvious link here https://www.vn750.com/forum/22-carbs-fuel-system/18121-have-read-many-posts-carbs-stuck-floats-need-advice-still.html
Sorry, haven't been back on here in a while. You only need one tool to remove that stuff. BOX CUTTER. Cut that crap out and throw in the trash. Marble until you get some coasters. That is all.
post #10 of 10 (permalink) Old 07-26-2019, 03:49 PM
Thread is new now.
Tags
carb , ear shave , emissions , float , jets
