engine stops at half tank even on reserve - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-09-2011, 07:36 AM Thread Starter
I hope someone here can give some advice, I have a 2000 VN750 which i really love but it has a problem with running at half full. I keep it on reserve all the time since it has a fuel indicator on the dashboard. But sometimes (only sometimes) when I ride at half tank the engine will just stop. If I pull over and wait about 10 minutes it usually starts right up again. I have always ran my bikes on reserve so that I do not have the hassle of running out of gas at the half tank mark and have never had a problem with any but this one.
Any advice is appreciated I love this bike in general but this is a problem and is really embarrassing since I am a kawasaki girl and brag about them all the time. So when I ride with the harley gang and it stops I want to push it in the ditch and leave it LOL
nomore09 is offline
post #2 of 9 (permalink) Old 05-09-2011, 07:41 AM
InvisiBill's Avatar
POOGS maybe?
1985 VN700 A1 (Sold) | 2009 Ninja 500R EX500D9F
VROC #32761
InvisiBill is offline
post #3 of 9 (permalink) Old 05-09-2011, 07:48 AM
JM2001's Avatar
Sorry to say, you are creating some of the problem. Do not ride on reserve all the time. The smaller pick up screen is probably clogged up . See recent thread. Possible POOGS.
https://www.vn750.com/forum/showthread.php?t=18108
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 9 (permalink) Old 05-09-2011, 10:03 AM
Member? ... check.
ZCraggRatt's Avatar
Sounds just like a case of the POOGS.
I think there is a real nice write-up (maybe sticky) on fixing the POOGS.
I'm sure you can search this forum and find it though.
P.S. - The nice write-up is by cglennon. If you go to the "carbs and fuel system" section of this forum, cglennon's sticky thread is second from the top.
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine - 10k mi.
Done: Coastered, .020 ign., Iridiums, VM, Plexistar II, MCCT's
Next: LED's
Will Do: MOSFET, Horns, Shave(maybe)
ZCraggRatt is offline
post #5 of 9 (permalink) Old 05-09-2011, 11:21 AM
Drive less, ride more...
theauhawk's Avatar
These symptoms are the classic "Phantom Gas Syndrome" (aka, POOGS) which is essentially a vapor lock issue with the bike's gas cap and/or venting.
Take note: there is nothing wrong really with your bike itself. It just needs some "preventive maintenance", ok?....
Using the above "search" function, do a search for "POOGS" or "phantom gas syndrome". In one of the resulting forum threads, another forum member, Cglennon, has a very nice write-up on how to service your bike to kill this condition.
Let us know how it goes....
'05 VN750
theauhawk is offline
post #6 of 9 (permalink) Old 05-09-2011, 09:06 PM
Big Dumb Viking
asbrand's Avatar
Send a message via AIM to asbrand Send a message via MSN to asbrand Send a message via Yahoo to asbrand
Easy way to tell if you have POOGS. Ride with the gas cap unlocked (thus open by a little bit). If the problem no longer happens...there ya go.
I had the same problem a few weeks ago. Fixed it by following the advice in the POOGS thread.
-Az
http://www.asbrand.com
1989 Kawasaki Vulcan 750
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
RAM GPS Mount w/Garmin GPS
Cigarette Lighter Power Adapter
Saddlemen's Classic Explorer Seat
Pro-Tac Driver's Backrest
LED Tail Light
LED Rear Turn Signals
Luggage Rack
Storage Trunk
Engine Guard w/Highway Pegs
Radiator Grill Cover
Turn Signal Relocation Bracket
Saddlebags
Floorboards
asbrand is offline
post #7 of 9 (permalink) Old 05-09-2011, 11:19 PM
cglennon`s "Phantom Out Of Gas Syndrome" Correction and Prevention service link:
https://www.vn750.com/forum/showthread.php?t=17572
post #8 of 9 (permalink) Old 05-09-2011, 11:30 PM
Patriot Guard Rider
The DEUCE's Avatar
I had the same issue. I ended up buying a new cap which solved my problem.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #9 of 9 (permalink) Old 05-10-2011, 01:46 AM
You might ought to look at your fuel lines too. If they arc up higher than the fuel outlets, you can have the same problem as POOGS because the fuel can't flow freely over the arc at a half tank cause there isn't sufficient gravity in the tank for the fuel.
IMHO the POOGS would happen before you get to a half tank of fuel. I had both my fuel lines arced higher than the outlets and it would starve for fuel unless I kept the tank full.
It happened to me last week. I could be wrong tho.
RakerBill is offline
