Pics of right side vent hose needed - please - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 05-02-2011, 11:10 AM Thread Starter
Git-R-Done!
AZ Kev's Avatar
Ok, I have been trying for the last week to figure out exactly where the vent hose that is supposed to go into the right side air cleaner is supposed to go, and I just can't seem to figure it out. I have taken the air cleaner housing off entirely, and I just can't see where the hose would go in. And if I ever did have such a hose, it seems to be completely missing now.
If anyone would be so kind as to maybe take their right side air cleaner housing off and take a pic of the hose going into it, I would REALLY appreciate it. I have looked in the service manual at the schematic and can see on there where it SAYS it is supposed to go. But when it comes to looking at my bike, well....?
A question too : if that house were to come off completely, would/could it cause the bike to run horribly, like missing really bad on one cylinder and not stay running? I wouldn't imagine that it would, but thought I would ask.
Thanks all!!!
AZ Kev
Arizona Kev
1989 VN750
7800 orig mi when purchased Jan 2011
Turned 11,000 mi Nov 2011
Saddlebags
Taillight relocation kit
Chad's highway peg mounts
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
Otherwise, all stock
"But it's a dry heat - like the inside of an oven"
AZ Kev is offline
post #2 of 17 (permalink) Old 05-02-2011, 11:32 AM
Concert connoisseur
wib714's Avatar
pg 2-16 gives a great breakdown of it, mine wasnt there either. thanks to "clock152" for pointing me in the right direction.
http://www.tocmanufacturing.com/File...nd%20Parts.pdf
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 17 (permalink) Old 05-02-2011, 11:35 AM
Concert connoisseur
wib714's Avatar
on the inside of each carb are two hoses that come up and join together in a t fitting, from there one hose goes to the right ear, on the rear of the ear there are 2 holes top and bottom, cut your hose in a slight angle and slip it into the hole in the ear
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 17 (permalink) Old 05-02-2011, 11:51 AM Thread Starter
Git-R-Done!
AZ Kev's Avatar
Thanks wib. You say yours wasn't there either - was it completely gone? I am assuming you ended up buying some hose and hooking it up, correct?
Even more importantly, how did your bike run without it?
Thanks for the info : )
AZ Kev
Arizona Kev
1989 VN750
Saddlebags
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
AZ Kev is offline
post #5 of 17 (permalink) Old 05-02-2011, 04:39 PM
JM2001's Avatar
AZ Kev
Mine came off last night while riding. The bike was running fine. Today I tried to re-attach it to the hole in the ear but the hose was so short I couldn't get it in. I went to Advance auto and bought a 12" piece of 1/4 " fuel line and a 1/4" to 1/4" vacuum hose connector. I ended up adding about 3" to the vent hose. I did cut it at a 45 degree angle. Worked great.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 17 (permalink) Old 05-02-2011, 05:30 PM
Concert connoisseur
wib714's Avatar
AZ Kev
I had a 3 inch piece of hose coming off each carb and sticking straight up (like a rain guage, LOL). like it was I would get sputtering and hesitation right at 60 mph. last year it even started doing it at lower speeds and gears. since the fix it has been great. I may have noticed a slight sputter but nothing like it was, it used to have trouble starting after rain or washing it but no more!
hose and a t fitting was about a two dollar fix!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #7 of 17 (permalink) Old 05-02-2011, 08:11 PM Thread Starter
Git-R-Done!
AZ Kev's Avatar
Thanks all. I took the air cleaner housing off again and finally saw the "hole" - actually more of a slot I guess, and that's why I was confused.
I appreciate all the detailed info you guys gave about the way your bike ran. Even though the hose is missing, I am confident that what I am experiencing is related to something more serious than just that. Fortunately, I can get it started, and it will run - albeit crappy - well enough to ride it the 4 miles to the shop to get it looked at. I'll let you all know what it was once I find out.
AZ Kev
Arizona Kev
1989 VN750
Saddlebags
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
AZ Kev is offline
post #8 of 17 (permalink) Old 05-03-2011, 07:19 AM
When I got my bike I seen that hose was just sitting under the tank (po got rid of the air boxs) so I capped it off and the bike would not run with it capped off. If your hose is missing and the bike is running bad it may be blocked by something. Maybe sucked up something in one carb, just a idea, not sure if it helps any.
slowz is offline
post #9 of 17 (permalink) Old 05-03-2011, 08:23 AM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #10 of 17 (permalink) Old 05-03-2011, 10:10 AM
clock152's Avatar
sounds like the PO didn't finish the "Ear Shave".. you will need to add a filter to the line coming from the T conection.
clock152 is offline
