Throttle Cable routing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 05-01-2011, 09:01 PM Thread Starter
Hey Guys, I know this sounds weird, but does anyone have a good detailed photo of thier throttle cable routing?? I just finished a stotor redo and the cables feel just a bit snug, although no problems with accelaration. I'm just curios if I've got them running correctly. I have a '03 model if that makes any difference. Thanks
IndyVN is offline
post #2 of 2 (permalink) Old 05-01-2011, 11:18 PM
Into the Darkness
NetMatrix's Avatar
Right above the radiator cap there is a wire holder or suppose to be on the bike. You run your cables through that and then behind the right ear (air filter housing) then down to your carbs. As far as being snug the throttle cables should not be snug at all you will need to spray some wd-40 at both ends of the cables, and you have to adjust the adjustment nuts on the carb and just below the housing so that they move freely without getting snug or anything.
English Version
ACCT to MCCT conversion video
https://www.vn750.com/forum/showthread.php?t=18235
ACCT to MCCT Conversion Thread created by wib714
https://www.vn750.com/forum/showthread.php?t=17917
Proximity Construction
NetMatrix is offline
