flooding back cylinder - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 04-22-2011, 12:06 PM Thread Starter
vulcan lover/hater
Unhappy flooding back cylinder
The bike ran perfectly last fall. When I got it out for the winter, reinstalled the tank, put a new diaphragm in the fuel tank valve (as I always do: the ethanol ruins it annually). I tried to start it, it runs for about 30 sec. on the front cylinder while the back cylinder floods: after several seconds begins dripping raw fuel out the first exhaust pipe joint. When I pull the plugs, the back ones are soaked.
Do I need to pull the carb and take it apart? My research has shown me that it is probably either a stuck float (likely) or a bad jet (unlikely: I don't know how a worn jet would cause this level of flooding, especially after running perfectly last fall).
I can't do anything (e.g. carb cleaner in the fuel) that requires the bike to run, because it doesn't run.
Chaz is offline
post #2 of 13 (permalink) Old 04-22-2011, 03:09 PM
bigbluezuk's Avatar
Based on the forums info, this is most probably a stuck float.
1995 VN750 - 10K
bigbluezuk is offline
post #3 of 13 (permalink) Old 04-23-2011, 12:41 AM
Agreed
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #4 of 13 (permalink) Old 04-23-2011, 09:06 AM
Heading to the DARKSIDE!
BRET H's Avatar
Hello....I just went through your same ordeal last week.....exact same problem.....The bike ran better than ever on a Tuesday.....that Friday the rear cylinder had raw unburnt fuel flooding the rear cylinder and dripping from the exhaust crush gasket area. I was baffled because my friend and I had just rebuilt the carbs a month and a half before........Turned out to be rear carb float was cracked and full of fuel causing the float to stay on the bottom of the bowl......yours could just be stuck.......mine was cracked.....food for thought.
BRET H is offline
post #5 of 13 (permalink) Old 04-23-2011, 10:43 AM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #6 of 13 (permalink) Old 04-24-2011, 10:34 AM Thread Starter
vulcan lover/hater
Thanks for this idea. Mine is the California emissions model, and just looking at the engine makes me woozy at the thought of removing carbs. But if I have to...
Chaz is offline
post #7 of 13 (permalink) Old 04-24-2011, 10:35 AM Thread Starter
vulcan lover/hater
Thanks! This forum is the best.
Chaz is offline
post #8 of 13 (permalink) Old 04-24-2011, 10:48 AM
BRET H's Avatar
California Emissions.....and you live in Ohio? Take all that useless crap off of there. working on the bike is a million times easier if you remove all that crap properly and coaster it and do an earshave. Also if you change to aftermarket exhaust and remove the goat's belly tank.....it's amazing how much more stuff you can get to.....not to mention the shedding of all that useless weight!
BRET H is offline
post #9 of 13 (permalink) Old 04-24-2011, 10:59 AM
What he said............best thing I ever did was rip all that junk off the bike.......
dariv is offline
post #10 of 13 (permalink) Old 04-24-2011, 11:53 AM Thread Starter
vulcan lover/hater
Thanks for the inspiration! It's nice to know that this can be done. Again...thanks!
Problem: I don't know what you mean by "coaster it"; something about the west "coast"? (Remember: my nickname for this site is "geezer"!) What's an "earshave"?
Chaz is offline
Tags
flooding , vn 750 carb
