First lo ride - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-08-2011, 10:02 AM Thread Starter
KenWilson's Avatar
Send a message via Yahoo to KenWilson
First lo ride
I started rding my bike to work today. First thing I found out is that I need warmer clothes. Also, the bike will not run smoothly without the choke set at 3/4 full. At 60 mph the bike spits and sputters alittle but if I slow down or accelerate it stops. Any suggestions?
Ken Wilson
1999 VN750-A21
Bought 4/1/11 Paid - $2000.00 - 8100 miles on it.
KenWilson is offline
post #2 of 9 (permalink) Old 04-08-2011, 10:16 AM
Mcneuby's Avatar
Cool Spitting and spudering
Give it a good shot of Sea Foam. Last fall I filled my bike with pure gas no alcohol and a few onces of Sea Foam. It started right up this spring and I don't think it ever ran better. I'm still running last falls gas. Been so cool that I haven't ridden it but a couple times yet this spring. I had never used Sea Foam before but after all the fans on this site I am strarting to become a believer.
Enjoy the Ride
Mcneuby
Mcneuby is offline
post #3 of 9 (permalink) Old 04-08-2011, 12:24 PM
johnm's Avatar
^^^x2 on the Sea Foam. Drain and flush both carbs. If that doesn't help...or perhaps in addition to, the idle adjust knob may need to be tweaked.
John
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #4 of 9 (permalink) Old 04-08-2011, 01:14 PM
Gemguy's Avatar
Ken after the bike warms up you should not be using your choke, I think that will eventually foul your plugs. If it doesn't idle after it's warmed up turn the idle knob on the left side under the gas tank till she runs at 1100 RPM.
~VROC~ # 389
Gemguy is offline
post #5 of 9 (permalink) Old 04-08-2011, 10:43 PM
Concert connoisseur
wib714's Avatar
I'm searching for the thread you need now, someone may beat me to it though!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #6 of 9 (permalink) Old 04-08-2011, 10:46 PM
clock152's Avatar
check that hose going to the right ear.. make sure its not out or bottemed out.. cut it at a 45 degree angle and put it back in the right ear... what happens is it there is to much air flow over it it is like blowing over a straw in your coke.. it sucks fuel out... and if it bottems out well its about the same issue.
clock152 is offline
post #7 of 9 (permalink) Old 04-08-2011, 10:47 PM
Concert connoisseur
wib714's Avatar
here it is, most of the info you need is on page two and three. try this first cause if its that, its a free fix!
https://www.vn750.com/forum/showthread.php?t=17300
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #8 of 9 (permalink) Old 04-08-2011, 10:57 PM
Concert connoisseur
wib714's Avatar
see! clock was 1 minute quicker!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #9 of 9 (permalink) Old 04-08-2011, 11:01 PM
clock152's Avatar
damn.. the wife tells me the same thing.... I am not sure who she is refering to when she says that.. but I guess I have the record!...glass half full kind of guy that I am!
clock152 is offline
