How to R&R the choke cable Without pictures! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 04-06-2011, 03:44 PM Thread Starter
dynajim's Avatar
I just finished R&R'g the choke cable. I was looking for pics of this. No one has em. Here's how and where to look to remove and eventually replace the choke cable:
On the left handle grip underneath you'll see a chrome adjuster. Loosen the 6mm lock nut and screw the adjuster in as far as it will go to give you slack at the carbs.
With the tank off, look at the left side carb. At the left towards the top of that carb, you'll see the enricher plunger for that carb. Slightly above and behind, you'll see a triangular piece that holds the bottom end of the choke cable. Pull on the metal part of the cable and slide the cable down. There's a slot for the cable to drop out or in for removal/installation.
While looking at the left side carb, now look to the right of the petcock and over at the backside of the right carb. You'll see where the choke cable attaches to the other side.
Now re-position yourself on the rt side of the bike. Looking at the right side carb, now look at the rear of it and you'll again see the enricher plunger and the cable connection. It has a slot system for removal/replacement also.
Now all this being said, I'm sure you'll now agree WHY no one has any pics. It's pretty near impossible (imho) to get a clear picture to post.
Hope this helps?
'94 VN 750 17k mi. Aqua, Memphis shade.
Acquired 2/2011
Oiled
Tank cleaned
New Fork seals
Idle jets-RT-3.0, Lft-2.5 turns
Sea Foamed
New Batt for grins
Stupid hose in the rt ear found and fixed
Major clutch adj.
New Petcock
New Shimko tires
De-goated before I got it.
Iridium plugs
YEA! New choke cable!!
Gonna do the Spline Lube soon(Chged tires before I found this site)
Replacement for my FXDWGI
Why didn't I find these before I spent $22 grand!!
dynajim is offline
