drilled wrong cap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 03-14-2011, 08:05 PM Thread Starter
truefate's Avatar
Question drilled wrong cap
ok so i wanted to drill the a/f caps out. i saw the photos but i didnt work on the bike for a few days after that and my memory must have been fuzzy because i driled the wrong hole. i realized this after gas began dripping out i have put some jb weld on and im waiting for it to cure (weather is gonna be crappy for a few days anyway) my question is will the jbwld hold and is there a better solution?
truefate is offline
post #2 of 22 (permalink) Old 03-14-2011, 08:09 PM
johnm's Avatar
Ooops. Sorry, man. That sucks. What exactly did you drill? A pic would be helpful here.
John
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #3 of 22 (permalink) Old 03-14-2011, 08:32 PM Thread Starter
truefate's Avatar
ok i marked the spot i drilled in red from this older pic. its actually the other cab but this pic had the best view of wht i drilled
truefate is offline
post #4 of 22 (permalink) Old 03-14-2011, 09:12 PM
Is the the float bowl drain?
km60155 is offline
post #5 of 22 (permalink) Old 03-14-2011, 09:22 PM Thread Starter
truefate's Avatar
no its right above it... i dont know what it is.. it was plugged with some sort of ...brass??.. ball (gold in color when drilling) i assume it is some sort of deleted "accesory" line for use in another set up on another machine (my best assumption) it dosen't seem to have any function on our bikes (except to confuse i nitwit like my self )
truefate is offline
post #6 of 22 (permalink) Old 03-15-2011, 06:44 AM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
And to leak out gas when You drill it out................
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #7 of 22 (permalink) Old 03-15-2011, 03:42 PM Thread Starter
truefate's Avatar
That's it does...and does it most efficiantly lol
truefate is offline
post #8 of 22 (permalink) Old 03-15-2011, 07:40 PM
Concert connoisseur
wib714's Avatar
why or what was you trying to drill out!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #9 of 22 (permalink) Old 03-16-2011, 05:42 AM Thread Starter
truefate's Avatar
caps covering the air/fuel ratio screws
truefate is offline
post #10 of 22 (permalink) Old 03-16-2011, 08:17 AM
How's the JB holding?
km60155 is offline
