Ear Shave Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 03-03-2011, 10:42 AM Thread Starter
Ear Shave Question
Where is the idle jet located on the carbs?
kephartj is offline
post #2 of 2 (permalink) Old 03-03-2011, 10:46 AM
I am quessing that the idle jet is the same as the pilot jet. It is in the small bowl at bottom of carb. The bowl is held on by three small bolts. If you are a good wrench, you can probably get to them without removing carbs. It is a slow and tiddious process.
You may need a small hose to replace the jets and bolts back into place.
