Rusty tank cleaning (Acid method) - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #21 of 28 (permalink) Old 07-27-2015, 04:58 PM
Pilgrim
Originally Posted by crowley1027 View Post
Also, lots of tiny nuts threaded on a long string will work. Drop the nuts in and secure the string somewhere. Untie when done and remove string of nuts
True, though might be better just tying the end nuts off and not securing the end, but letting both ends loose so while shaking the tank the whole bundle is free to fly around in the tank. Like the chain, when your done you'd still only need to catch any part of it and pull the rest out with it.
(just sayin')
TheDV8
"Theoretically what we really need here is a neutron flux high enough to bypass the gaps of instability."
A6ULdv8 is offline
post #22 of 28 (permalink) Old 09-09-2016, 12:55 PM
I'm a rider
One1's Avatar
Since I see no pics
https://www.vn750.com/forum/22-carbs-...ml#post1126474
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #23 of 28 (permalink) Old 09-23-2018, 11:53 PM
I did this today it took about 4 hours from start to finish and my tank that looked just like that picture is brand new thanks again furgy..
Mack Johnson is offline
post #24 of 28 (permalink) Old 06-23-2019, 01:06 PM
MSattler's Avatar
So I just poured the 16 ounces of naval jelly in the tank, and I was wondering if I am supposed to now add water? I shook the tank around after resealing it, but I wouldnít imagine that did much.
'08 Road King Classic
'86 VN750 with the following work done to it, after sitting for 19 years:
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #25 of 28 (permalink) Old 06-23-2019, 02:10 PM
Originally Posted by MSattler View Post
So I just poured the 16 ounces of naval jelly in the tank, and I was wondering if I am supposed to now add water? I shook the tank around after resealing it, but I wouldn’t imagine that did much.
Not sure about adding water to the naval jelly. You might have to turn the tank periodically to get it coated.
Be careful with water and muriatic acid though! Adding water to acid makes a violent reaction.
I used white vinegar to clean up some rusty tools. Worked great. Left one wrench in too long (three weeks) and it took the chrome off. Rinse the vinegar out afterward.
post #26 of 28 (permalink) Old 06-23-2019, 02:53 PM
MSattler's Avatar
Thank you for the advice. I got through the process without looking like a Parisian. I donít have a before photo, but here is the after photo. I sprayed wd-40 in it, which is why it looks wet. The neck should give you an idea of how it looked. I just put my gas float back in, and the cap is going on next.
Update - the petcock is now pouring out of both carb tubes, and the selector does nothing. Looks like I will have to reassemble it
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #27 of 28 (permalink) Old 06-23-2019, 04:50 PM
Looks good. I expected a lot more rust.
post #28 of 28 (permalink) Old 09-25-2019, 04:33 PM
Just wanted to post my results. Followed fergy's instructions to a T, except instead of using nuts and bolts, I used 3 feet of the smallest steel chain that Home Depot had. Made getting the chain out much easier at the end. 100% recommend. Thank you so much for this post!
mdub23 is offline
