Not a Kawasaki gas cap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 02-12-2011, 12:11 PM Thread Starter
Blake W.
cowboydesperado's Avatar
The PO said the cap was from a Suzuki. I was wondering if that may cause problems since I've seen on some forums here that the stock cap makes a seal and has some vent system. My cap just sits in the hole and no seal. Having issues with not being able to open full throttle and has a misfire running up through the gears. Sounds like its not getting fuel. I have adjusted the AMS and coasterd, cleaned the carbs and put iridium plugs. Idles great but just skips as you go through the gears and can't go full throttle. Could this be a cap problem?
1991 Vulcan 750
29800 miles
Coastered...3 1/2 turns
MCCT....home built from old ACCT
"Custom" Metallic Black paint....me and a can....lol....Looks damn good though.
AGM battery
Volt meter
Gutted goats belly
Harley Screamin Eagle mufflers
Spline lube....and mine actaully had grease upon inspection but regreased anyway
Metzler ME880 170/80/15 on rear
Pics coming soon...as soon as I find the camera
cowboydesperado is offline
post #2 of 6 (permalink) Old 02-12-2011, 12:23 PM
Real easy to find out...take the cap off and go for a ride.
The problems with the stock cap are due to it "sealing" to well...not the opposite.
Sounds like you could have carb issues.... diid anyone check the float bowl height? (this is the point where the float cuts off fuel entering the carb)
Is the vent lines off the carbs that run to the right ear OK? many cut the end off at a 45 degree angle so it won't bottom out....and those that have done an earshave have to find an area of still air under the tank to route the tube.
Does the motor stumble when the bike is parked or only when you ride it?
post #3 of 6 (permalink) Old 02-12-2011, 12:35 PM Thread Starter
Blake W.
I have the tube run into thr right ear in the little square hole towards the rear...wouldn't fit into the original holder. Only does this when riding. Gonna try the no gas cap ride and see what happens.
1991 Vulcan 750
29800 miles
AGM battery
Volt meter
Gutted goats belly
post #4 of 6 (permalink) Old 02-12-2011, 12:39 PM Thread Starter
Blake W.
Does the same with no cap. Figured mine wasn't sealing enogh to let the petcock use vacuum to pull the gas to the carbs under accleration.
1991 Vulcan 750
29800 miles
AGM battery
Volt meter
Gutted goats belly
post #5 of 6 (permalink) Old 02-12-2011, 02:27 PM
deleted
FlacoLove is offline
post #6 of 6 (permalink) Old 02-12-2011, 03:25 PM Thread Starter
Blake W.
Ok figured it was not the cap. Had to go from 2 1/2 turns on AMS to 3 1/2. Runs better now. Still backfires and sputters and no way on full throttle....just wants to completly die then until throttle is released. Would rejetting help?
1991 Vulcan 750
29800 miles
AGM battery
Volt meter
Gutted goats belly
