Easy air box removal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 01-15-2011, 12:57 PM Thread Starter
I Hope this helps any vulcan owners
Remove tank, old filter ears and plastic boots. I used a red hot hacksaw
blade to remove my plastic air box. I used some tape to make a handle and using a propane torch heated the end of the blade red hot. Then melting and cutting the box into removable sized pieces. I cut- melted the top of the box then removed the carb boots using some wd-40. Keep heating the blade red hot and slice the box into pieces. total time 1 1/2 hrs. Be careful not to cut or melt any hoses and wires. Not messy and fairly easy.
Bob
hegman is offline
post #2 of 19 (permalink) Old 01-15-2011, 05:35 PM
I wish I had thought of that when I took mine out.The second time I took it out whole.
post #3 of 19 (permalink) Old 01-16-2011, 09:59 AM
clock152's Avatar
I used the wifes big azz bread cutting knife... it took a while..
clock152 is offline
post #4 of 19 (permalink) Old 01-16-2011, 02:47 PM
Young Gun
kc_matt's Avatar
hhmm... Maybe a cheap soldering iron would work as well? Wouldn't have to keep reheating it.
1990 VN 750
First (hopefully last) time in the shop:
Carb rebuild New brakes front and back New radiator fan
I've done:
Spline Lube New (used - non-leaky) Gas Tank New Fork Seals New Pirelli tires New Yuasa Maintenance Free Battery
Fresh Dexcool coolant Upgraded Shunt-type R/R (Relocated) Headlight Bypass Stator tested - PASSED
Clutch Swap - EBC Street Racer Frictions with new eBayed steels ACCT to MCCT conversion
kc_matt is offline
post #5 of 19 (permalink) Old 01-17-2011, 10:55 PM
1985 VN-700
L2fish's Avatar
I had my engine in after the stator replacement and forgot to put the airbox back in. Had to drop the motor as I want to keep mine stock. Funny as in the first shot motor went right in. After dropping for the airbox it took 30 minutes of wrestling
L2fish is offline
post #6 of 19 (permalink) Old 01-29-2011, 05:55 PM
no other way
so really there is no other way to remove my airbox? It wont come out in front or anything? ugh....
adwalker67 is offline
post #7 of 19 (permalink) Old 01-29-2011, 06:09 PM
You can remove the fuel tank and some water hose and work the box backwards between the frame. It is not easy, but it does work.
post #8 of 19 (permalink) Old 01-29-2011, 06:14 PM
ok thanks...cutting it is not an option for me at the moment...dont wanna do an ear shave cause i have no clue what it is lol
post #9 of 19 (permalink) Old 02-02-2011, 07:38 PM
mine came out pretty easy by making one cut where breather tubes go in the air box and slid it out the back
shadowman is offline
post #10 of 19 (permalink) Old 07-30-2014, 09:12 AM
mge_1's Avatar
Send a message via AIM to mge_1 Send a message via Yahoo to mge_1 Send a message via Skype™ to mge_1
I'll have to try this. Good thread. Thanks.
mge_1 is offline
