will not start/backfiring - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 27 (permalink) Old 11-05-2010, 10:08 PM Thread Starter
Exclamation
just so there is no confusion, the bike backfires while cranking, it does not starts, it just backfires while cranking
nicknack2 is offline
post #12 of 27 (permalink) Old 11-06-2010, 02:55 AM
Originally Posted by nicknack2 View Post
I understand the easiness of having lifetime plugs and 0-maintenance battery, but how does that relates to the backfiring, I'm not worried about the no start-the air/fuel mixure at this time, my main concern right at this time is why is it back firing, it appears as if it was out of timing...
The timing is not adjustable. There is no distributor or ignition points, it is electronically controlled. As far as I know, the only way the timing can change mechanically is if the cam chains and gears become so worn that the chains jump a cog.
If your new battery has plugs on top to allow adding water, it is a wet cell, not maintenance free. I started my bike last week after it has sat for 3 or 4 months w/o being started. My MF battery was new in April, and cranked the engine over for several seconds until the vacuum operated petcock let fuel fill the carbs, then it fired right up on Seafoam treated fuel that has been in the tank since my accident 28 months ago.
Pull all the plugs and examine them for wear and if they are wet. If any electrode edges are rounded off by spark erosion they will need more power to create a hot spark. The Iridium plugs have a harder electrode surface and resist rounding off for up to 100K miles.
Not sure about backfiring, but it may be caused by too lean fuel mix I think.
post #13 of 27 (permalink) Old 11-06-2010, 11:07 AM Thread Starter
Exclamation
I agree, lean air/fuel mixture will cause backfiring when decelerating and pinging while accelerating, but w/ the choke wide open the mixture it is really rich... like I said the problem is while cranking...I know there is a tech/mech in the forum that has my answer...
post #14 of 27 (permalink) Old 10-11-2016, 02:58 PM
Matthew Wellington's Avatar
I'm interested to find this out because my 86 VN750 is doing the exact same thing!
Matthew Wellington is offline
post #15 of 27 (permalink) Old 10-11-2016, 03:01 PM
I have been having issues for months and I have to jump start the bike every time I stop. Please help us
post #16 of 27 (permalink) Old 10-11-2016, 03:41 PM
heaney750's Avatar
have you played with the idle screw make sure it didnt back out of the adjuster on the carb mine did and i had the no start backfire just like that took me a while to find the problem
heaney750 is offline
post #17 of 27 (permalink) Old 10-11-2016, 03:44 PM
AGM battery and iridium plugs solved my problems. Same with just about everyone else here. Do not bother running a standard battery with cheapo plugs.
Pickup coil gap mod and pickup coil relay mod also greatly improve ignition.
post #18 of 27 (permalink) Old 10-12-2016, 11:22 AM
@Matthew Wellington : When I purchased my vn it came with a 'new battery', but after a few months it started dying every time I parked it. New battery solved the problem. If your bike starts with a jump, it means you've got low voltage or insufficient cranking amps from your battery. Try cleaning your battery terminals and take your battery to a car-parts store for a health check.
Vulcan slang for newcomers
Service Manual Download
Thorn is online now
post #19 of 27 (permalink) Old 10-12-2016, 11:46 AM
Malta Mick's Avatar
talking about no maintenance batteries, can someone give me the reference/part number of the one needed for the 750 please.
also, i currently run with standard NGK's , are the iridium that much better ?
Malta Mick is offline
post #20 of 27 (permalink) Old 10-12-2016, 12:38 PM
Yes the Iridium are *that* much better on our bikes (our ignition isn't exactly the best, so anything helps). NGK Iridium Plugs #7803/DPR7EIX-9
Here is a list of batteries: Batteries - Vulcan750.net Wiki
