Simple question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 10-25-2010, 02:00 PM Thread Starter
Papa Smurf's Avatar
Simple question
Probably an obvious do it/don't do it, but it is always best to ask the experts before doing something potentially dumb. My helmet locks and gas tank lock are/is sticking. Whenever this happened with my bicycle lock I would just add some WD-40 and it would free right up. If I add a touch of WD-40 to the gas lock (by opening the slot slightly with the key and giving a quick squirt) would this have a poor affect on how the engine runs/gasoline? I am sure some of it will get into the gas.
Thanks in advance.
Papa Smurf is offline
post #2 of 8 (permalink) Old 10-25-2010, 02:18 PM
If you are worried about getting some wd into the fuel, it won't hurt it any.
post #3 of 8 (permalink) Old 10-25-2010, 02:34 PM
X2^ spray on friend!
post #4 of 8 (permalink) Old 10-25-2010, 02:50 PM
A graphite lube made for locks would be a better choice. I doubt it would have any adverse effects if some made it into the fuel, but you don't need to use much for it to work.
WD-40 doesn't last longer as a lube anyhow.
post #5 of 8 (permalink) Old 10-25-2010, 03:29 PM
Originally Posted by Papa Smurf View Post
gas tank lock is sticking.
Thanks in advance.
A reminder: Press down on the cap when turning the key??
VoIPDoc is offline
post #6 of 8 (permalink) Old 10-25-2010, 04:06 PM Thread Starter
Papa Smurf's Avatar
Thanks guys. I just wanted to double check.
I have tried pressing down, jiggling, turning it the other way first; when it catches it feels almost gritty on the key turn. I figured a touch of WD-40 could be helpful.
While I was Googling for info on this I found something fun. Apparently you can seat the bead of a tire by spraying WD-40 in it and lighting it on fire.
http://www.youtube.com/watch?v=myi-MxNCI4o
post #7 of 8 (permalink) Old 10-25-2010, 08:33 PM
Yes you can.. or even ether (a.k.a Starting Fluid), I have done it numerous times in a pinch.. how ever very unrecommended.
post #8 of 8 (permalink) Old 10-27-2010, 04:41 PM
MANIC MECHANIC
vulcanjoe's Avatar
but its so much fun. safety clean brand brake clean just catches fire.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
