Upping "jets" with stock exhaust??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-01-2010, 09:26 PM Thread Starter
Normally I hear us talking about having to "re-jet" carbs when changing to aftermarket exhaust, etc....but has anyone stepped up carb jetting with the stock exhaust?? How far can I go?? Want some more ooomph! Running stock ears/intake and exhaust. Thanks.
Choirboy750 is offline
post #2 of 6 (permalink) Old 10-01-2010, 09:36 PM
MANIC MECHANIC
vulcanjoe's Avatar
I did originally I kept the stock pilot jet and went to a 142 main. It didn't really make a difference.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 6 (permalink) Old 10-01-2010, 10:29 PM Thread Starter
Sooo...straight up. How do do I get more ummph...
post #4 of 6 (permalink) Old 10-01-2010, 10:43 PM
straight up more oomph.. do an ear shave, gap the coil pickups, and remove the goat. ohh and make sure that you are firing on both cylinders. these are the the best performance mods to do (and the only ones that can be done cheaply).
post #5 of 6 (permalink) Old 10-03-2010, 12:08 AM
You might find this link interesting. Read the Dial-A-Jet tech article at the bottom.
http://www.thunderproducts.com/IntelaJet.htm
Somebody on this board posted about installing one on his vn750 a short time ago.
He was riding throught the mountains and some pretty big elevation changes, and said it worked very well.
Even if you are a flatlander, the pre-atomized fuel charge sounds like it greatly improves throttle response.
post #6 of 6 (permalink) Old 10-03-2010, 10:56 AM
dirtrack650's Avatar
Even with the stock exhaust you can get a bit more power and response with the ear shave. Anytime you change your intake, you need adjust your air fuel mix.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
