Coasters - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 09-15-2010, 09:46 AM Thread Starter
MoBuSee's Avatar
Question Coasters
when replacing the reed valves and putting coasters, do i need anything else besides the coasters? do i need any caps for anything else as the old system must connect somewhere and need to be caped? i havint ripped it apart yet so i dont know thats why im asking thanks.
upgrades:
v&h crusers
HID kit blue
coasters
weight reduction
paint
chrome fill tank cover
engine guards
de-badged
progressive shocks
MoBuSee is offline
post #2 of 7 (permalink) Old 09-15-2010, 09:51 AM
baldy's Avatar
When you remove all the hoses you need to cap off where they went. RE; The small hose that goes to the right side carb needs a cap and the hose that goes to the breather plennum needs to be plugged.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #3 of 7 (permalink) Old 09-15-2010, 11:20 AM
Baldy means that the carb port needs to be capped, not neccarielly the hose itself.
I made my coasters from about 1/8 inch aluminum. Use the reed valve for a pattern. If you are careful with the gasket it can be reused. I also used a small amount of rtv silicone sealent.
post #4 of 7 (permalink) Old 09-15-2010, 03:56 PM
Ceal's Avatar
what is that breather plenum you mention? Is it the hole on the bottom of the airbox?
Ceal is offline
post #5 of 7 (permalink) Old 09-15-2010, 06:54 PM
Here`s a link to the verses, and probably more information than you want to read on coastering or marbling. LOL
Info there too on adjusting fuel settings on carb to reduce or eliminate popping and backfiring in exhaust.
https://www.vn750.com/forum/showthread.php?t=1083
post #6 of 7 (permalink) Old 09-16-2010, 07:57 AM
baldy's Avatar
Yes the air box. Some have just plugged the hose but if you can get to it the hole in the airbox can be plugged off with a rubber plug/grommet.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #7 of 7 (permalink) Old 09-16-2010, 11:58 AM Thread Starter
MoBuSee's Avatar
Cool thanks
upgrades:
v&h crusers
HID kit blue
coasters
weight reduction
paint
engine guards
de-badged
progressive shocks
MoBuSee is offline
