Fuel Tap Assembly - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-24-2010, 02:22 PM Thread Starter
Fuel Tap Assembly
We have just bought a 1993 VN750-A9 and it won't start.
It seems although it's due to fuel shortage, as we can not get petrol passed the fuel tap. We taken it apart all the rubber diaphagms are fine, but cant seem to get fuel past the tap?
Any ideas? or suggestions to try.......
EricandLiney is offline
post #2 of 5 (permalink) Old 08-24-2010, 03:50 PM
The fuel will only pass through if you pull a vaccum on the system. It does not free flow when you open the petcock.
post #3 of 5 (permalink) Old 08-24-2010, 05:45 PM
Yes, the middle nipple on the petcock needs vacuum applied to allow fuel to flow from the two outside nipples. Sucking on a short hose attached to the middle nipple should work, to apply vacuum to test it.
I have some salvaged syringes from a vetrinarian that I use for transfering liquids like brake fluid out of the master cylinder, or adding water to a battery while wrenching on the car or bike. I haven`t tried it yet, but if the syringe end will fit snugly on the hose to the vacuum nipple, it should apply vacuum as well.
BTW, Welcome to the Vulcan madness.
post #4 of 5 (permalink) Old 05-25-2015, 11:06 AM
these bikes are hard work
poedale is offline
post #5 of 5 (permalink) Old 05-26-2015, 08:23 PM
2000 VN 750 Senior Member
At times and the thread you are using is from 2010 so that shows how difficult it can really be. lol
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
