Custom exhaust question. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-23-2010, 01:26 PM Thread Starter
MoBuSee's Avatar
i have a 1997 vn750 in stock mint condition. i just ordered new V&H pipes, im wondering if i have to do anything to the carbs? thanks in advance. im in south florida at sea level.
MoBuSee is offline
post #2 of 8 (permalink) Old 08-23-2010, 02:07 PM
You should only need to re-jet if you get rid of the stock filters and put on those pod filters. Install the exhaust and go for a ride.
post #3 of 8 (permalink) Old 08-23-2010, 10:10 PM
baldy's Avatar
Putting these pipes on doesn't require re-jetting but you will hear more popping at decel so coastering it and turning the air/fuel screws out to 2.5 turns will stop the popping considerably.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #4 of 8 (permalink) Old 08-24-2010, 01:10 PM Thread Starter
MoBuSee's Avatar
and where exactly is this screw located you speak of?
MoBuSee is offline
post #5 of 8 (permalink) Old 08-24-2010, 04:33 PM
baldy's Avatar
If the carbs have never been adjusted the screws are protected by a factory plug. Both plugs are just under the vent hose on each carb. There is a wright up about how to do this procedure in the versus threads in the carbs section/reduce popping threads.
https://www.vn750.com/forum/showthread.php?t=1083
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #6 of 8 (permalink) Old 08-24-2010, 09:05 PM
gregtheplumber's Avatar
arent they under the vac hoses not the vents?
gregtheplumber is offline
post #7 of 8 (permalink) Old 08-24-2010, 10:08 PM
baldy's Avatar
Sorry. Yes they are vac hoses. Had a brain fart there. lol
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #8 of 8 (permalink) Old 08-25-2010, 12:58 PM Thread Starter
MoBuSee's Avatar
Alright thanks for the help again. i can get an idea from the versus thread but some pictures would help to be exact, but ill just fit the new pipes on first and see what happens before i go altering the carbs.
MoBuSee is offline
