carb hose locations - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 08-23-2010, 11:04 AM Thread Starter
carb hose locations
i am putting my bike back together and i cant remember where all the hoses from the carbs go. i had way to many things going on i didnt get it back together as fast as i wanted. anyways there are 4 hoses coming off the carbs and three go the the on off valve and i think one goes to the vent on the back of the tank but not sure, the longer one that i thought went there gets kinked when i try to put it there.
any info would be verry helpfull of pics would be even better thanks
01 750 vulcan
just bought
collom7 is offline
post #2 of 11 (permalink) Old 08-23-2010, 11:20 AM
baldy's Avatar
The one that goes to the breather comes from the top center of the 2 carbs from the "T". The one on the right carb by the air/fuel screw goes back to the valve under the seat. Check the carb section. I believe there are pics of the hoses and where they go.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #3 of 11 (permalink) Old 08-23-2010, 11:24 AM
johnm's Avatar
IIRC, 2 fuel hoses go to the petcock. One for ON/PRI and one for Reserve. The other to the petcock is a vent hose (middle position). There should be 2 more hoses, one from each carb that connects to a "T" fitting. A single hose from the "T" vents to the right side ear. Someone correct me if I'm wrong. Hope this helps.
John
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #4 of 11 (permalink) Old 08-23-2010, 11:55 AM Thread Starter
the one from the T is the one i thought went to the breather on the bottom back of the tank, when you say right ear do you mean air filter? cuz i cant see a nipple for the hose to go on.
thanks
01 750 vulcan
just bought
collom7 is offline
post #5 of 11 (permalink) Old 08-23-2010, 12:02 PM
baldy's Avatar
The one from the "T" is the hose that goes to the right ear goes in a spot on the breather cover at the top rear of it. If you run your finger just inside the edge of the cover you can feel it. The hose just slides in to that but make sure you cut the hose at a 45 degree angle to keep it from bottoming out.
You may have to route it up between the boots of the carbs to get it from kinking.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #6 of 11 (permalink) Old 08-23-2010, 01:43 PM Thread Starter
i figured it out, thanks for your help
01 750 vulcan
just bought
collom7 is offline
post #7 of 11 (permalink) Old 08-23-2010, 10:57 PM
John
CORRECTION johnm.
Middle nipple on the petcock is a vacuum line from engine to open fuel valve only when engine is running.
The two fuel lines to each side of the vacuum line, from the petcock go to a separate fuel bowl on each carb.
ON, PRIME (only the 3 or 4 earliest model years have prime position that allows fuel to flow w/o vacuum) and RESERVE positions feed both fuel lines.
You are correct about the vent lines from the carbs to the "T" and right side ear.
It has taken me a long time to get all this straight too.
I will see if I can recognize all the lines on the bike later when I actually have to work on the carbs.
post #8 of 11 (permalink) Old 08-24-2010, 12:49 PM
johnm's Avatar
Appreciate the correction, Gordon. I am rather new to this bike and was working from memory which usually gets me in trouble (CRS disease, LOL).
John
1989 VN750
VROC#31798
johnm is offline
post #9 of 11 (permalink) Old 07-23-2017, 12:52 AM
Matthew Wellington's Avatar
I'm not understanding. I have 3 lines to my petcock, I have one that goes to the valve under my seat, then I have another tube, the tube the connects between my carbs but I don't see any "t" fitting..
Matthew Wellington is offline
post #10 of 11 (permalink) Old 07-23-2017, 08:21 AM
3 hoses on the petcock. center one goes to the vacuum line on left (front) carb, the other 2 go to the carbs for feeding fuel. none should go under the seat. the right side carb (rear) vacuum port goes under the seat to the valve for the emissions stuff.
michiganteddybear is offline
